Gas mileage difference C6 vs 4-speed
Old 09-22-2010, 02:17 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Can anyone who has done a C6 to 4-speed manual trans conversion, tell me the gas mileage difference they got after the swap? Any engine but particularly 351w.
Thanks
Old 09-22-2010, 04:57 PM
bashby's Avatar
bashby
bashby is offline
Are you talking about an OD 4 speed? I've heard a C6 uses about 30 hp so you should see some improvement, even without OD.
Old 09-23-2010, 12:53 AM
Ken Blythen
No, not an OD 4-spd - just a straight 1:1 top gear trans......T18, NP435 etc.
I've read a few times, somewhere, that a C6 uses up to 65hp.
But I'd like to hear of the experience on both mileage & power, of anyone who had done a C6/4spd swap, in either direction.
Old 09-25-2010, 01:15 PM
Ken Blythen
Anyone able to help?
Old 09-25-2010, 01:53 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
I don't have any experience with swapping a c6 with a 4 speed. I did swap a c6 for a zf 5 speed(which has overdrive) and gained 3mpg. So I would assume the 4 speed would be something less than 3mpg.
I find it hard to believe that the c6 would soak up 65hp, since most of these old v8's didn't make much over 150hp(302, 351w) and that would be almost half the power output of the engine.
I would guess you might see 1-2mpg increase. If you look at all the old car and truck EPA specs, the auto loses about 1-2mpg to the manual correct?
Old 09-25-2010, 02:00 PM
PaulzF150's Avatar
PaulzF150
PaulzF150 is offline
I've had 2 of these trucks, both with the I-6. The first one, an '83, had a 2.47 rear and a 3 on the tree. The one I have now, an '85, has the C6 and a 3.55 rear. The '83 used to get as much as 22 mpg on the highway. My '85 gets about 13. At 65-70, the '85 is churning at 3000 rpms. Generally, especially with these older trucks, you get better gas mileage from a standard shift that you would an automatic. Also keep in mind that your 351 will probably not rev as high as an I6 at 70 mph, due to the extra power. Frankly, I would go with the standard shift. Hope this helps.
Old 09-25-2010, 08:47 PM
Ken Blythen
Thanks for the replies.
I don't know exactly how the hp usage is worked out - it can't be a constant, so maybe the highest loss isn't until full-on at 5-6000 rpm?
The more I dig, the more the 60ish hp figure comes up. And around 15hp for the 4 speed transmissions.
And yet one guy with 302 in an older F1, swapped from a 4spd to a C6, & said he couldn't notice any power loss driving..........he wasn't sure on his mileage.
Old 09-25-2010, 10:46 PM
fordsgofaster's Avatar
fordsgofaster
fordsgofaster is offline
I can't help much either but I'm fairly confident that the 55 - 60 hp loss is from drag racing guys comparisons & their most likely pulling down 500- 700hp or so on the dyno. I doubt the drag at cruise would be as hugely significant.
I have no doubt it probably does take some more turning at cruise than a t18 have no idea how much but my truck has a c6 & its not like you can feel it pulling the motor down at cruise or anything I average 11.7MPG absolutely loaded to the hilt. don't know what it dose unloaded it nearly never is.
Old 09-26-2010, 03:14 AM
PaulzF150's Avatar
PaulzF150
Ken, A little off topic....but I really like the picture of your truck. I am looking to repaint mine, which is the same color, but different 2-tone style than yours. I like the two tone style of your truck better. Would you be able to create an album of your truck. I want to see how your tailgate is painted. Thanks.
Old 09-26-2010, 03:45 AM
Ken Blythen
No trouble, Paul - just might take a couple of days
Old 09-26-2010, 01:19 PM
Ken Blythen
Thanks, fordsgofaster - is that imperial gallons?
Old 09-26-2010, 01:26 PM
Ken Blythen
Paul,
I've added some photos showing the tailgate to my existing album '83 F250 XLT' (via my public profile), that were sent to me by the trucks previous owner when I was looking at buying it.
Let me know, I can take some better quality ones if you would like.
Ken
Old 09-26-2010, 02:22 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
The C6 has no lock up torque convertor so it will be spinning a couple hundered RPMs more than the 4 speed manual in top gear. Other than that i really cant see milage loss while cruising
Old 09-27-2010, 02:15 AM
Ken Blythen
Dave - was that in your diesel, or a gas-engine truck?
Old 09-27-2010, 04:59 PM
fordsgofaster
To be honest I'm not sure, I used a conversion calculator on the net to convert it & I don't remember which one.
Our speed zones & such are in metric here so we also talk metric figures for fuel consumption. It uses 1liter per 5 kilometers, what we call 5 kays per liter. I forgot to I run 3:5 diff gears for economy reasons, acts like an overdrive so my figures won't be comparable anyways.
Quick Reply: Gas mileage difference C6 vs 4-speed
