460 EFI vs Carb in a E350?
I'm looking at purchasing an older motorhome between 1985 and 1996.
What year did they switch over to EFI?
Which engine is more reliable?
Is the performance about the same?
Do the carb engines have the exhaust manifold issues like the EFI?
Do they all use a C6 transmissions? If not, what transmission replaced it? If replaced, was it a better transmission than the C6?
Thanks,
Mark
Thanks,
Mark
85 or 86 was the last year on the vans I believe. On the trucks some very early 87s had a carb. But most were EFI. With EFI you will get a little better mileage a mile or two per gallon. If you want gas mileage don't buy a 460. Most 460 guys will tell you that also. I run an 86 F250 4x4 460 C-6 with a Hughes tow converter, 6 pack forward clutch included in a Trans-Go kit. & I have other mods to engine & I get 9-10 miles per gallon if I stay out of it. An EFI will get 12 mpg maybe a little more.
07f250diesel
07-10-2014 08:04 PM
CDF302v8
22
01-05-2011 11:22 AM
martimani85F250
02-02-2006 07:25 PM
