My 58 F100 project
Old 04-01-2012, 12:10 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
I still liked the Slotted D Mags, but the Salt Flat wheels look good on there too.
  #77
Old 04-21-2012, 10:26 PM
lwclark's Avatar
lwclark
lwclark is offline
Hey Run4CVR, I'm curious - how did you get around the Passive Anti-theft System on that late-model Ford V8 you swapped in? Are you installing its gauge cluster and key assembly?
[I just re-read the first page and note that you're using a Sullivan carb intake, so no EFI, so no PATS. Never mind. ]
  #78
Old 04-22-2012, 08:28 AM
gtilton.as's Avatar
gtilton.as
gtilton.as is offline
Wow, is all I have to say. You are both ambitious and skilled.
  #79
Old 04-22-2012, 01:11 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
I am curious as to why you swapped out the EFI for a carb intake. Nice looking build by the way.
  #80
Old 04-22-2012, 07:18 PM
Lowered IQ's Avatar
Lowered IQ
Lowered IQ is offline
That is an awesome truck. I love it.
  #81
Old 04-23-2012, 10:25 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
The intakes on the 5.4 are big and ugly (about 18 inches high and 18 inches wide ) they just look goofy and with this setup its just impessive looking when the hood is opened. sullivan also builds this intake for injectors and a throttlebody, i was going for simple and fill the engine bay.
Thanks for the compliments
Jeff
  #82
Old 07-09-2012, 05:52 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
I got my gauges and panel set up thought I would update everyone heres how it turned out what do you think?
Also got my steering column and steering wheel
I got a rebuilt c-4 trans also just need to get my converter (special build) and I made plates to block all the holes in the firewall
Thanks Jeff
  #83
Old 07-09-2012, 06:12 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
The truck is looking good Jeff. I like that steering wheel and liked the way you moved your brake MC, I did something very similar. The panels for you fire wall cleaned it up real nice.
Strong work.
  #84
Old 07-09-2012, 06:20 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
Thanks Teddy I think it turned out pretty good
I got the engine cleaned up and painted with my new K&N filter and Demon carb
The C-4 trans painted with the JW bell housing for the 5.4 Modular
Jeff
  #85
Old 07-09-2012, 07:12 PM
Tomget's Avatar
Tomget
Tomget is offline
Gauges..Nice
  #86
Old 07-09-2012, 07:57 PM
THartman's Avatar
THartman
THartman is offline
Gauges look good. What type are they and where from?
  #87
Old 07-09-2012, 08:02 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
Classic Instruments Silver Series got them through Kenny's Rod Shop in Boise Idaho
Thanks
Jeff
  #88
Old 07-10-2012, 12:16 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,132 Likes on 2,656 Posts
It's all looking really good, I like your gauges and that motor looks super.
  #89
Old 07-20-2012, 07:21 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
Tail light install 50 Pontiac
Thanks Jeff
  #90
Old 09-08-2012, 11:17 PM
RUN4CVR's Avatar
RUN4CVR
RUN4CVR is offline
Hello everyone I painted my dash and mounted the gauges , *****, and stereo trying to make some progress with the parts I have hope you like the pics.
I'm thinking of puting a power port in where the lighter was and still need to figure out what to put in the other little hole between the right side *****. Mine had a plug there
but I 've seen some pics on google with a throttle T-hamdle there do you guys have any ideas instead of a plug?
thanks
Jeff
Quick Reply: My 58 F100 project
