Need advice...Water in my fuel tank. My dumb move.
Hi there.
I did something really dumb and I'm looking for advice.
I have a 2001 7.3L F350 with about 115 000 miles on it.
My dad sold his farm and gave me some diesel in cans that he had on the farm. He didn't think it was too old and it was in a clean metal five gallon can so I thought I would be OK for cleanliness to use it a little at a time in my truck. I wasn't even thinking about water in the fuel but as the fuel was clean but it must have sat through one or two cold winters and there was condensation happening in the can.
Needless to say I dumped about half of the can in my tank and when I started up and drove for a bit, the water in fuel light came on and she died with a plume of white smoke out the tail pipe while sitting idling in front of a store waiting for my wife to come out. I shouldn't have but I panicked and tried cranking it for a while to get her going to no avail.
I towed it home and dumped the fuel bowl with my hose off the drain tube and the water was very evident. I changed the filter and ran some more with the electric pump in the tank a few times by bumping the key to start the pump.
After the new filter was changed, she was running rough but now it seems to be OK. My Water in Fuel light came on again when I started out this morning but I stopped after a few miles and drained my fuel bowl again and the light went out. It hasn't come on again since.
Question: Is there anything with my engine I may have damaged? I did crank for a bit when I was trying to get it going the first time and someone told me that I shouldn't do that as there would be little engine lubrication if it wasn't starting and I could damage my cylinder walls.
Also: Do I have to change my fuel filter again? I bought two when I had this happen so I'm carrying a spare.
We are leaving on a camping trip tomorrow so I just want to be sure things won't go sideways on me on my trip.
Any advice is appreciated as I'm new to diesel trucks.
You could hook a hose to the drain line and cycle your pump several times pumping out fuel. You may not have that much, but yes I would change filters again and probably again if you water light comes on again. IF he smoke has cleared up and it's running better, then you are probably all right on the engine.
I think your motor/injectors will be fine.These are tough ole motors.I would have suggested you drain/pump out the fuel in the tank and get all the water out.Fill w/clean fuel.If the tank is low now I would still get that diesel/water out before your trip.
If the tank has alot of fuel in it I would add some Diesel Kleen(Walmart,AZ,Oreilly's) to the tank.Take another look at your filter and see if there are water beeds on it and possibly change it and buy another filter for your trip.The filter is to trap particles....not water.
You are worrying to much.... it will be fine.
Have you seen some of the 'stuff' guys run through these trucks..... AFT oil.... veggie oil.....Hydrogen spray.... propane....
A little water will not hurt it. I think there is a additive at parts stores to evaporate water.... Fill it up and run it. The fuel filter should be fine. It may 'burp' every now and then until it is run out, but the little bit will not hurt it. After your trip, take the fuel filter out and check for dirt and other material in the bottom of the bowl that might need to be cleaned out...
welcome to the forum
you will learn a lot here. If you have any questions... ask away.... the guys here will not steer you wrong, they/we all talk things out and find the right 'fix'..
dknouse
Thanks for your help
Thanks for the quick and knowledgable replies.
I spent a lot of time researching before I bought my truck and looked at over 50 different units of different years of Dodge, GM and Ford before deciding that I needed a 7.3L. What really tipped the scales for me wasn't only the positive reviews of the 7.3 but also this forum and the number of knowledgable, dedicated people that are willing to help at a moments notice.
Thanks again.
Thanks again.
