1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Reset TPMS 2011 F350...please help! :)
Old 09-01-2010, 03:15 PM
admorris's Avatar
admorris
admorris is offline
Just got larger tires on my truck and tire pressure monitor light is on. How would I go about resetting this? VERY much appreciated in advance!
Alan
Old 09-01-2010, 03:22 PM
Byram's Avatar
Byram
Byram is offline
Discount tire reset mine when I got the tires... I assume the shop where you got tires could help..
Sorry - I din't know how to reset myself....
Old 09-01-2010, 03:30 PM
admorris's Avatar
admorris
admorris is offline
Place I had tires put on just said to drive over 45mph for a couple mins. and it would reset itself. That didn't happen. Anyone else have ideas?
Old 09-01-2010, 03:42 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Read the Owner's Manual?
Old 09-01-2010, 03:47 PM
Byram's Avatar
Byram
Byram is offline
Page 236 Owners manual
Old 09-01-2010, 05:19 PM
admorris's Avatar
admorris
admorris is offline
I left the damn thing at home, but I'm guessing it says to do what I had already done up to that point, which is to drive it for a little while over a certain speed and it will reset. Anyway, I took it down the street to the Ford dealer and they had to use their reset tool to do it...no cost, no big deal.
thanks for the suggestions of reading the owners manual.
Old 09-09-2010, 08:00 PM
boulderbronco's Avatar
boulderbronco
boulderbronco is offline
What pressure are you running in your new tires? I just got new oversized tires today and they couldn't reset the damn thing. The max psi is 50 on these new tires so thats where they are. I can't imagine the TPMS on the F350 freaks out at 50psi!
Old 09-09-2010, 09:16 PM
admorris's Avatar
admorris
admorris is offline
Actually, if you follow directions on page 236 you can reset the monitors yo whatever pressure you want. I am running mine at 65 right now but am going to reset to 55 tomorrow.
Old 09-09-2010, 09:31 PM
bpounds's Avatar
bpounds
bpounds is online now
Too late for you guys, but if you buy the proper tires for your truck you won't have this issue.
Old 09-10-2010, 05:48 PM
admorris's Avatar
admorris
admorris is offline
Wow, thanks for the great advice. I bought load range E tires specifically b/c I had an F350 thinking that was enough, but I gave Ford too much credit. I didn't realize they had a backward *** monitoring system. Amazing to me that they wouldn't think that maybe there are people out there that would change tires on their trucks and maybe a few of those people would have 65psi tires vs. 80psi tires.
Old 09-10-2010, 07:48 PM
bpounds's Avatar
bpounds
Most load range E are 80 psi. What tire did you buy?
Nevermind, I see it in your sig. That is an E range 65 psi. Buyer beware I guess, which was the point I was trying to make.
Old 09-10-2010, 08:32 PM
admorris's Avatar
admorris
admorris is offline
Yea, not trying to bust your chops...I understood what you were saying. I just can't believe I am either stuck with 80psi car tires for my truck, or a damn warning light. Not everyone that owns an F350 tows 12k lbs or hauls 4k lbs in the bed. I'm really hoping there is a workaround for this, as I cannot possibly be the only one who has replaced those go-kart tires for mud tires.
Old 09-10-2010, 09:03 PM
admorris's Avatar
admorris
admorris is offline
Hey, the earlier comment I made about running any pressure you want was actually wrong. The tpms will freak out on anything that is 25% below the preset limit (80psi on the rear of the 350, 65psi on the front)- really really annoying if you ask me. If you find something different or a way around it please please please let me know.
Old 09-10-2010, 09:31 PM
Rick Cargo's Avatar
Rick Cargo
Rick Cargo is offline
I talked to a ford service advisor today about a re-flash and the low tire pressure warning and he said that these sensors will send an alarm at any pressure under 55 psi. because these tires are rating for a minimum of 65psi. and max of 80psi. I had the warning this week when a tire got 54.5 psi. He also said that if you get after market tires and rims you need to use the sensor valve stems or stare at the low pressure tire light indicator. Or put a piece of tape over the light. Thats what Rancho Ford said.
Old 09-10-2010, 09:42 PM
admorris's Avatar
admorris
admorris is offline
Hey Rick, I would be ok with 55psi, but I'm getting light at anything under 62psi. From what I understand, the tpms comes on for any pressure 25% below the Ford specs (65 front, 80 rear) which would be 60 rear and 48.75 front. Are you saying that anything under 55 all the way around is what is needed to throw off code?
Quick Reply: Reset TPMS 2011 F350...please help! :)
