NH End of 2010 chat thread
#80
do you need the antenna mast or the mount.
I am guessing the screw on the mount that holds the mast is snapped off. Get a new mount at the dealership. should be about $15..... I think???.... I probably have an extra mast kicking around somewhere. No mounts and all the mounts I find at the salvage yard have broken screws or they brake when I go to check them.
Use Ken's discount. Might be cheaper... Maybe???
As for rims. Get 15" for winter. There are allow 15's if that's what you want, rubber is cheaper. I have 15" Mercury Cougar rims. Any cougar rims from the newer 97 or 98 and newer FWD cougar.
I actually just ruined one of my 01 Limited edition S2 rims. Broke an aluminum lug and had to drill it out and drilled into the lug seat enough so I really can't use it.
#82
Morning New Hamster...24 hours no posts...what's up with that???
Check out the OCT GTG Thread...Dan's started a sign up list!!!
#90
Howdy Dan...Ron...I'm headed to 1 Main Street tomorrow...almost 6 minutes away!!!
Dan...Conway MA or NH???
