Need help.. 00 Excursion V10 shutting off
Hello, my V10 Excursion is giving me a little bit of a hard time. Once warm, it shuts off when I go from drive to reverse and when I have to brake hard.
I cleaned the mass air flow sensor and replaced the idle air valve behind the throttle body. Not sure what else I can do. Any and all help with this issue is greatly appreciated. Thanks in advance.
The check engine light has never come on. It doesn't die out or bog when it's still, it's only when I'm driving and have to brake a little harder than usual or when I go from drive to reverse.
Do the brakes feel any differently? I'd check for vacuum leaks using something like an intake cleaner spray. With the engine running, lightly spray the cleaner on each vacuum hose connection and see if there are any changes to the RPMs.
The transmission symptoms are a little strange. I'd start with testing the battery and the alternator as low voltage can cause some really strange symptoms. Even if one or the other is new - have them tested as new parts can be weak or not be performing at 100%.
My 2001 V10 has a similar issue. Mine will shut off when shifting from park to reverse or from reverse to drive. It has only done it a handful of times and it is usually right after starting first thing in the morning and pulling out of the drive way. It starts up fine right after and then drives fine as well. No check engine lights either. Guess I'll wait until it causes more problems.
