change 2001 from DRW to SRW
Old 08-25-2010, 12:30 AM
jd3rdnoah's Avatar
jd3rdnoah
jd3rdnoah is offline
I have a 2001 f-350 DRW Cab and chassis. I want to change to SRW. Are the rear ends the same width? Do all I have to do is change the wheels to SRW's. Any other problems I might have?
Thanks for any information.
Old 08-25-2010, 08:11 AM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
No, the rear ends are completely different. I have one if your close to Fl.
Old 08-25-2010, 08:30 AM
jd3rdnoah's Avatar
jd3rdnoah
I am going to try to be in FL for labor day (Orlando) if my truck has the motor changed by then. Do you know what gear is in it?
Old 08-25-2010, 08:42 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Why are you changing to a SRW?
Old 08-25-2010, 08:47 AM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Its 3.73 LS out of a 99, and I'll be about an hour away from Orlando on labor day myself.
Old 08-25-2010, 09:39 AM
jd3rdnoah's Avatar
jd3rdnoah
Fuel econmy and want to put a bed on it are the main reasons. SRW beds are more than 1/2 the price and in better shape around here. I am having the motor changed out now and can't afford a dually bed. I only haul 2 horses a couple times a month and not that far (less than 100 miles).
Old 08-25-2010, 10:33 AM
miller_feed
I didn't think a truck bed would fit on a chassis cab frame? I've been wrong before, I think. lol
Old 08-25-2010, 12:33 PM
jd3rdnoah's Avatar
jd3rdnoah
It had a dually bed on it before I purchased it. The guy wrecked the bed and took it off.
Old 08-25-2010, 02:41 PM
mongo75's Avatar
mongo75
mongo75 is offline
have you looked into getting fender flares for a dually and putting them on a standard bed? All Ford does is cut out some sheet metal so the tires wont hit it, and screw on the fenders and call it done. That may be cheaper than swapping the rear.
Old 08-25-2010, 02:59 PM
jd3rdnoah's Avatar
jd3rdnoah
I have looked at that idea. From what I found out the flares will not cover the wheels all the way.
If you know of some that do, let me know.
Old 08-25-2010, 05:53 PM
mongo75's Avatar
mongo75
mongo75 is offline
Well, I meant the factory dually fenders, not just some aftermarket mud-slingin' protection. You can usually find some on ebay for a decent price. All depends on how much looking you do to determine what is cheaper, and more practical for you to do. I bought a dually for a dumb reason- I think they're friggin sexy lookin' and I tell her that all the time LOL. But now years later that I tow for side money, I feel a heck of a lot better with 4 wheels supporting the kingpin on a 14k trailer that just 2. If I lose a tire, I can safely pull over fairly easy. With a regular rear end, you're lucky not to have a hell of a time getting off the road. All depends what you want to do.
Old 08-25-2010, 06:16 PM
jd3rdnoah's Avatar
jd3rdnoah
Thanks. that is some good information. With how much I am going to have in this baby, I might want to get a 2 car hauler. I also could use it to haul hay. I am retired so I will have a lot of time on my hands.
Old 08-25-2010, 06:31 PM
mongo75's Avatar
mongo75
mongo75 is offline
Well there ya go brother! Get yourself a trailer, go on Uship.com, and make some money!
Old 08-25-2010, 08:16 PM
dn29626's Avatar
dn29626
dn29626 is offline
Well, I meant the factory dually fenders, not just some aftermarket mud-slingin' protection...better with 4 wheels supporting ... If I lose a tire, I can safely pull over ... All depends what you want to do.
You lost me with the "if i lose a tire". Do you have a set of lug nuts for each wheel (two sets on each side of the rear)? My studs are not that long.
I agree with you on the dually fenders.
Old 08-25-2010, 08:38 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
He means blowing a rear tire, not physically losing one.
Quick Reply: change 2001 from DRW to SRW
