All ive got right now is the ram. Still looking for an orbital valve.
Originally Posted by captain p4
Hey tin man, just curious don't blow a butthurt fuse, are you planning on beefing up the link tabs on the axle end? they look kind of flimsy from the pictures. The material looks thick enough, but looks liek they need boxed in and/or some lateral bracing.
Its 1/2" tabs and are very stout. I highly doubt they will bend or anything, there is a ton of trucks down here running the same setup with more lift and bigger tires that have no problems.
Its 1/2" tabs and are very stout. I highly doubt they will bend or anything, there is a ton of trucks down here running the same setup with more lift and bigger tires that have no problems. Thanks Nick
^^^was thinking the same thing. I don't see why people make huge tabs like that. Provides more leverage on te weld, and the longer the tabs, the more likely to break/bend.
EXACTLY.....thats why it aggrivates me. I designed those tabs so i can get my coilover mounts over the kingpins. i sent my file to plasma cutter and he sold that design to lots and lots of people.
i laugh when i see some tard using them when a regular tab would be much much better. that is a gigantic moment at the base of the welds. the links shouldn't be an issue but when used in c/o mounts its just unnecessary.
If you are still looking for a steering valve, check the Sauer-Danfoss OPSM-40-on out. It's an open center unit that will still give you steering if the pump craps out. The only bad part is the non reactive part, but I can tell you it worked well in my case. Here's the valve I just put in:
Got the drivers side subframe done. I know its a little different than the "planned" picture I posted, but some of those cuts are damn near impossible without the right tools. Regardless, once the pass side is done and I do my cross-supports its going to be pretty solid.
hey tin, shipping is $16 for slow mail or $30 for fast mail. let me know if you are still interested and what suits your time frame better. gotta get a box too. 2 ft cams don't fit anything that my local p.o. happens to have. damn hick towns
i do, but i don't know how to use it. seriously, my hillbilly *** would prefer a money order. i've never shipped anything like this. i deal locally with hilljacks i'm used to. me scared of teh intranetz!!!!
