You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
remove the driveshaft, and take it to your big vise.
find a socket to fit inside where the cup goes, and squeeze lightly to remove the spring clip
remove from vise, and remove the spring clip
find a larger socket than the cup, but smaller than the driveshaft, place small socket on one side, large on the other, then squeeze it out with the vise, you may need a pipe for leverage. it will go crack twice, then it will shove the cap into the socket
place 1 cup in the drive shaft, turn the new joint in, make sure to face all u joints in the same direction, or they will bind. place 2nd cap on, and squeeze carefully with the vise, until the caps are flush with the outside
squeeze the cap in with the socket until you can see the slot where the spring clip goes, on both sides.
install new spring clips
install grease fitting
bolt it back in the truck, use blue loctite on the nuts to keep them from backing off.
good luck, as you see, not a hard job, just take your time
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
"If more sane people were armed, the crazy people would get off fewer shots."
"Some people are alive because it's illegal to shoot them"
ok, so..... I do the picture in with paste, then hit enter? they have changed photobucket, and you know me..... slow learner.
__________________
You can also hit "PREVIEW POST" prior to posting it. That way you get to see how it's gonna look when you DO post it and if you don't like it, edit it.
You hit the "ENTER" button here in FTE, not in PhotoBucket. All you will see here is the URL to PhotoBucket. Hit the "ENTER" button as many times as spaces you want
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family) Join the Maryland Chapter click HERE
thanks. did you notice the 2' x 2' x 3/4" piece of road plate under it?
__________________
