swaybar
swaybar
Adding both bars is the best way to go. Adding a front only will make the truck understeer even more than it does in stock from, adding only a rear will make it oversteer.
I can vouch for the fact that putting on only a rear sway bar can lead to some very odd and unpredictable handling. Addco strongly cautions not to do it. I ended up running a rear bar only on my F150 for a few weeks due to parts availability and it was VERY squirrelly. I put on the matching front bar and it became rock steady and much better overall than it was without the bars.
swaybar
The Addcos are a bolt on EXCEPT that you need the front spring perches with the eyes and the end links from a truck originally equipped with a factory bar to mount the front bar, They're available at the junkyard of your choice. The rear is a pure bolt-on. I didn't even need a drill, some models may require one.
Bootlegger's Deluxe
03-03-2011 07:31 PM
mtflat
11-16-2002 12:44 PM
