Steering Box Mount area.
Old 08-19-2010, 08:34 PM
hotrodbob51's Avatar
hotrodbob51
hotrodbob51 is offline
I was told by a friend that it would be a good idea to beef up the frame around my steering box. I did notice that it flexed some when you turn the wheels. Has anyone done something to there like this?
Old 08-19-2010, 08:55 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
I've never heard that, and I just completely rebuilt my entire front end. The frame iself is designed to be flexible.
But if your frame (which is 1/4 inch thick 3 sided channel) is flexing when you turn the wheels, I'd definately be looking at the set up for weakness in YOUR frame.
Old 08-19-2010, 09:06 PM
hotrodbob51
I have not seen anything wrong myself. Just wanted to see if anyone may have some input. Thanks.
Old 08-19-2010, 09:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Are you sure the bolts are tight? They are famous for coming loose over time.
Old 08-19-2010, 09:41 PM
hotrodbob51
They are not real tight for now because I am still working on it. I was just asking the question to see if there was a problem in this area. From what I can see on mine it is not cracked any where.
Old 08-19-2010, 11:09 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Friend must be a Chevy guy, THEY are famous for cracking in that area
Old 08-20-2010, 12:18 PM
eman92082's Avatar
eman92082
eman92082 is offline
I haven't heard of anyone needing to re-inforce this area on their frame and there's a lot of Truck-Heads on this site. My only caution would be that if you do make some changes, consider where the energy will transfer to. Short of boxing the entire frame whatever you do will find the easiest path to release.
Old 09-12-2010, 11:07 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
I had a 51 frame one time with a problem in the steering box location. The frame was stressed and severely cracked all around the bolt area. It was too bad to be fixed. A patient person would have had to cut out a one foot section and replace it. This would not be a safe remedy.
