Thanks Bjorn it looks sold looking forward to see it on the truck I'm still straggling with the Mustang II IFs kit but last night finally there is progress
What's the length of your steering column 30" or 32" I'm in the process of ordering ididit column but not shore about the length?
Keep up the good work its gona look perfect when it's done, but make sure that the frame is strait and square befor you start wilding, I made a mistake not checking it was leveled but the right frame rail was 1/4" forwarded so I had to remove the crossmember and made sure that the frame was square, I hop you understand what I mention I'm bad in English
Good luck and have fun
My truck almost done just waiting to get it back from the paint shop
frame is square but we gonne bolt it to the frame not weld it
If I weld it IK dont get a numberplate and can't drive it
That are the rules here in Netherlands not welding the frame
almost is the subframe ready all the gaps are filled so the subframe wil fit like a glove on the frame
here are some pictures next step is making the weld smooth and round
this was not a easy job
Wow you did a great job, that's a lot of fabrication, you have a very good wilding skills.
The trafic rules here are the same can't wild any thing to the frame
