Project ford f100 1956 new pics
#46
#48
#49
The stock 390 will have about 300- 330 depending on the carb, cam, and model of 390.
Here is a specification table for the Ford FE engines:
Ford "FE" Engine Specifications
#51
my new order at mar-k
Will ship together with my truck
<HR>Rear Pans
Smooth with Box, Full Height
Rear pan is made of 18-gage electro-galvanized steel and may bolt or weld on depending on your desired look. The "full height" rear pan is taller than our standard pan and extends down and forward to completely fill the space below the bed sides and between the rear fenders. This rear pan will give your truck a custom smooth look with the license tag indention (tag box). Instructions included. Made in Oklahoma City, USA.
<FORM id=frmOrder name=frmOrder action=orderAddP.aspx>
</FORM>
<HR>Rear Pans
</FORM>
#53
same I have on mine, I think.. there are two
one goes straight down to the bottom edge...
and mine curves.
one customization some people do is to extend/close the bottom of the stake pocket right there at the roll pan.
with the curved on like mine, you can't really do that.. it looks totally weird..
.. heres a couple pics of mine shows the gap closed at the fender and a rear shot with the under bed gas tank
had to trim the roll pan edge a little to make it all fit..
Sam
and mine curves.
Sam
#55
#57
#60
Try www.summitracing.com . They have a large selection to choose from. If you want something more expensive and very cool, check out www.mooneyes.com or www.billetspecialties.com. Happy hunting.
