Cooling system issue - overpressurization?
Old 08-20-2010, 03:58 PM
GammaDriver's Avatar
GammaDriver
GammaDriver is offline
Heya gents,
My 1999 4.6L is running well, but I'm using coolant / water to some degree, AND it's as if I have an over pressurized system.
I say over-pressurized because I blew an original heater hose once, but it happened AFTER I shut the truck off and walked away from it. At that time I knew that my filler-cap would occasionally whistle (letting out pressure), so I bought a new, and proper-pressure, filler cap for the truck shortly after replacing that hose.
But even with the new one I hear it off-gassing when I shut the truck off some days, and today I both heard it while driving AND the temperature gauge started rising at a stop light. (I thought that is was out of water, so I drove it some more to get to a parking lot, but the temp gauge went right back to normal and stayed there both at the next stop lights and in the parking lot, and when I finally could open the reservoir, it had plenty of water in it.)
So I'm left guessing at a few causes here.
Where is my water going to? Yeah, I don't want to think it is, but certainly a head gasket could be an issue - but I never see any steam out of the exhaust.
What is causing the over-pressurization? Well, that could be a head gasket, too, but could it be a stuck thermostat? I only ask based on what I saw the temp gauge do today.
I wish I could just find an external leak and know that that's where my water goes, but... ugh.
Still, if there is an over-pressurization, perhaps the water is being pushed out of an overflow tube since the cap is often letting pressure out (whistling)?
I really can't figure out why it would both whistle, and nearly overheat, if there was enough water in the system today.
Old 08-20-2010, 09:31 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
EXCURSIONATOR1 is offline
I had the same thing happen on my non ford. It was a stuck thermostat. Or a semi-stuck thermostat .
Old 08-25-2010, 01:10 PM
fordinlinesix's Avatar
fordinlinesix
fordinlinesix is offline
Sounds like:
A) What Excursionator said about the thermostat
or
B) Something is plugged up in your cooling system
Tylor Reynolds
04-25-2014 09:59 PM
ghanson
1999 to 2016 Super Duty
08-13-2011 08:55 AM
Navyguns
Aerostar
09-09-2009 09:16 AM
samdog
Modular V10 (6.8l)
07-05-2006 12:02 PM
luke_trash
19
03-08-2005 02:09 PM
Quick Reply: Cooling system issue - overpressurization?
