What did you do to the X today?
Old 08-24-2015, 08:09 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
  #37022
Old 08-24-2015, 08:43 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
Memories of the dual m90's on a 302 Thunderbird come to mind... I left a bunch of m90 supercoupe stuff behind when I moved. Curious to see how this turns out!
  #37023
Old 08-24-2015, 09:22 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Ok, you got me, what kinda engine you stuffing all that air into?
  #37024
Old 08-24-2015, 09:40 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
Worked on my cummins swap a bit.
Mocked up mounts for the ford a/c compressor and alternator.
Power steering is all hooked up, just needs fluid.
Sorted out throttle cable, although I may need to limit pedal travel some. I used the stock v-10 throttle bracket and modded it. The cable itself is quite long, so there is a big loop I'll have to tuck away.
Swapped to the newer air horn (it looks better imo)
Moved the battery from the pass. side to the drivers. The stock tray was able to be flipped around and 2 of the 4 holes lined right up.
Shortened front driveshaft and installed it.
Loosely bolted in the rear shaft to see how short it is. Will need one 2" longer. Fun fact, I have an extended cab short bed super duty parts truck (wrecked it last fall) and its rear driveshaft is 2" longer than the Ex's. Win.
Cut a hole in the floor for the shifter. Turns out there is a hvac duct right there for I guess the second row floor vents which went in the trash can.
Mounted fuel filter and ran fuel line from it to the pump.
  #37025
Old 08-25-2015, 12:57 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I paid the bill on my Expedition and brought it home to do more work before it was road ready again. Finished it up this evening and she's back in action! The Excursion can go back to resting now after a few days of Daily Driver duty again.
I figured you guys would get a kick out of this....
  #37026
Old 08-25-2015, 11:43 AM
AzPatMan's Avatar
AzPatMan
AzPatMan is offline
Just got back from hang'n out with RiffRaff over the weekend.
Did a fuel bowl rebuild and put in his FRx on the EX.
  #37027
Old 08-25-2015, 12:22 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
Took my X for emissions testing today. She passed with flying colors! Pretty proud that the diesel sniff test on opacity showed 2.6 out of the permissible 20.
  #37028
Old 08-25-2015, 12:52 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
love your fleet
  #37029
Old 08-25-2015, 03:12 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Originally Posted by LivingLarge
I'm lake hopping in the south...
Attachment 122532
Originally Posted by WE3ZS
That is a sweet little RIB Michael, I meant to comment on it when you first posted the pic of it. It has to move along pretty well too!
Originally Posted by Stewart_H
Oooooooo, Tom is right! That is a sweet looking RHIB!
Got any better pics of it? How fast will it go? How many people will it hold?
Stewart
Thanks guys, the speedometer was not hooked up, no GPS but I'm going to guess somewhere close to 50mph with 3 adults onboard.
It's a zodiac yacht line 480 DL, specs show 9 passengers ( that would be tight).
I really just bought it for this trip, but after using it last few days I'm thinking add the GPS, Bimini Top and have speedo looked at. May just have to keep this one for a while. New engine now has 6 hours ...
I'll post more pics when I get back.
Still no GPS, but speedo reads 42 mph... So, looks like 50 would be wishful thinking....
  #37030
Old 08-25-2015, 06:12 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
Replaced my junk Rancho shocks with my new Bilstiens. While compressing the Rancho on the back to get the bolt out, it pissed fluid all over!It shouldn't do that after only a year! I guess now I know why it bottomed out easier than I thought it should!
  #37031
Old 08-25-2015, 09:24 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Just topping her off
  #37032
Old 08-25-2015, 11:13 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Which Rancho's did you have? Have you tried contacting them for warranty?
Ford Truck Enthusiasts Forums - View Profile: Rancho Suspension
  #37033
Old 08-26-2015, 12:17 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Originally Posted by ufvj217
love your fleet
I kinda like them myself, I hope to keep this fleet for a long time. I've already had the Expedition 5 years and the Excursion will be 5 years in October
  #37034
Old 08-26-2015, 11:35 AM
LivingLarge
John those are amazing numbers
  #37035
Old 08-26-2015, 11:59 AM
nmclella's Avatar
nmclella
nmclella is offline
Sold the old tow mirrors for a cool $150
Quick Reply: What did you do to the X today?
