What did you do to the X today?
Old 03-29-2015, 07:07 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
As far as I know they are just pass throughs from the hinge area to next to the fuse block. There may be a keyed hot wire in the group, I didn't poke around that much, just used one of them. Great idea really.
  #33542
Old 03-29-2015, 07:11 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
The 4 wires just pass through and are not connected to anything (and just fyi, I found the interior side of mine next to the brake controller plug).
There is yet another wire under there that is switched 12v (apparently, I didn't see it but then again I wasn't looking for it)
  #33543
Old 03-29-2015, 07:17 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Finally some weather nice enough to work on the Ex a little. Installed my Air Lift air springs today. I am going to put together an on board air setup, but haven't bought a tank or compressor yet. Going to just use the Schrader valves to inflate for now. Installed the valves on my trailer plug bracket.
  #33544
Old 03-29-2015, 07:26 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
Looks good, IMASAP!
  #33545
Old 03-29-2015, 07:35 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Nice bag install! Love the shrader location!
  #33546
Old 03-29-2015, 08:45 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
I found the separate white w light blue stripe that is above and to the right of obd2 plug.
Pretty sure it's keyed on hot from first hand experience from previous poster.
What I still can't determine is taped with the RED / WHITE / BLUE / BLACK wires in interior is 3 smaller gauge wires that I cannot find on the engine side where the other ends of RED / WHITE / BLUE / BLACK wires are.
Currently I'm trying to get the key code off the sticker by the radio area.....not being successful
  #33547
Old 03-29-2015, 08:53 PM
nmclella's Avatar
nmclella
nmclella is offline
Originally Posted by JuanHuevos
Did you do a write up on this? If not, you should consider it.
Will do!
So back on the tire hunt.
Saw these on Kijiji...
Hercules 285/75r16 new! | tires, rims | Bathurst | Kijiji
They are however load range D...
http://www.herculestire.com/tire-gal...terra-trac-dt/
My question is would these work on a stock rim and would they be heavy-duty enough for the Ex. They are rated at 3300 per tire.
I think I could get him down to the $700-800 range.
What do you guys think?
As always I appreciate your help and incite. I rarely tow and when I do its just a 14 ft runabout boat.
Thanks,
Nate
  #33548
Old 03-29-2015, 10:49 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
D's are fine, buy'em and get those little 245's off!
Headed out to Wasilla today, got to see my two old Ex's
my old 2004 next to my 2002
Skip, here's a pic of the door
  #33549
Old 03-29-2015, 11:13 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
Currently I'm trying to get the key code off the sticker by the radio area.....not being successful[/QUOTE]
I'm an idiot.... after half hour dicking with getting the cup holder out due to lack of correct tools at my home, I realized the code I was trying that I found via the mirror trick was correct.
While "reversing" the individual numbers as appear on the sticker, I failed to reverse the whole number sequence...
Must have been that long straight shot from Disneyland that we landed at midnight on that has me screwed up...
I can say one thing the fact there is no "keep the domelight off" feature is a real dumb mess up on Fords part.
I will be doing that Mod soon. 900 miles straight thru with having two kids in car seats getting blinded and awaken up unnessarily at the crack of a door being opened is pretty irritating.
  #33550
Old 03-30-2015, 07:20 AM
fordboy67's Avatar
fordboy67
Nate, those are some meaty treads! Would look nice on the X!
  #33551
Old 03-30-2015, 08:25 AM
El_Coqui's Avatar
El_Coqui
El_Coqui is offline
Made my best mod to my ex yet! Meet Izabella Rubí....my prettiest traveling companion(next to my wife ) to ride with Papa in "The Kraken"
  #33552
Old 03-30-2015, 08:41 AM
RobRoss's Avatar
RobRoss
RobRoss is offline
Congratulations!
  #33553
Old 03-30-2015, 08:47 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
  #33554
Old 03-30-2015, 08:55 AM
IMASAP's Avatar
IMASAP
IMASAP is offline
Congratulations !!
  #33555
Old 03-30-2015, 10:16 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 7,237 Likes on 2,257 Posts
Originally Posted by Snowseeker
Here is a pic of me.
I had no idea you were so tall
Quick Reply: What did you do to the X today?
