What did you do to the X today?
Old 09-27-2014, 05:33 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
After all that you better have a few!
I washed the front end of mine the other day just to get the bugs off. Maybe I'll get the mid section another day and then the rear. lol
  #29237
Old 09-27-2014, 11:56 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Let's hope you don't service your women with the same half *** "I'll get it all done eventually" approach
  #29238
Old 09-28-2014, 12:35 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
how are you expected to get 2 people actually into them back seat? lift them over the rear from the hatch?
  #29239
Old 09-28-2014, 07:22 AM
Splash67's Avatar
Splash67
Splash67 is offline
Both sides of the middle bench fold and slide forward with the seat latch. We've had 3 adults in the back on many occasions. It's tight but it works out just fine.
Sent from my Samsung Galaxy S5 using IB AutoGroup
  #29240
Old 09-28-2014, 07:25 AM
FLO98's Avatar
FLO98
FLO98 is offline
I think they were asking how people access the fourth row in that one.
  #29241
Old 09-28-2014, 07:32 AM
Splash67's Avatar
Splash67
Splash67 is offline
Ahhh...I see it now. I wish I had such a seat.
  #29242
Old 09-28-2014, 08:03 AM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
I've seen that 4th row before. It's an aftermarket addition. Great idea, but eats into the storage area. And with seating for 10, you'll need every inch of storage you can get!
  #29243
Old 09-28-2014, 09:42 AM
Snowseeker's Avatar
Snowseeker
"Thanks honey, I'll get you later."
That 4th row does look like it is facing forward, good question how people are supposed to get back there. lol If it was closer I would go see it for sure. It is around a 2 hours drive away from me.
  #29244
Old 09-28-2014, 11:04 AM
NorthwesternCowboy's Avatar
NorthwesternCowboy
NorthwesternCowboy is offline
All settled in our new house (first time home owners, whoop!) and I finally have some time to play around in the garage so I decided to dig into some of the technical issues the Ex has had since I bought it. Always been curious what it would look like with the running boards removed, so off they came. Think I'm going to do a fun lighting upgrade while they are off and reseal off the housings since water puddles up pretty bad on mine. Or maybe try to find some of the newer super duty running boards to put on instead. Who knows.
Also decided to finally figure out which door was causing the dern door ajar light to be on all the time. After pulling off every door panel and removing the plug to the sensors one at a time I was able to weed out the left passenger door as the culprit. Pulling all the panels off also let me on to the fact that the nooks and crannies of the Ex are filled with dust and need to be cleaned up. Its like the previous owners parked the thing out in the desert. I think I will swap out all the door lock actuators and whatever window motors are having trouble while everything is apart. Even found one of the windows control switches dangling down in the door that I thought was missing.
And now that the door ajar light is resolved, I need to go figure out causes for the lights not coming on when doors are ajar (assuming previous owners disabled them), running lights not working, and trailer running lights not working (trailer brake lights are the only ones working). Going to look into fun interior lighting upgrades while I'm at all this. Maybe even the dash swap for more buttons and stuff.
Pics are after running board removal, a couple to show current condition of the rear hatch, a component of the door lock subsystem I found just hanging in the right passenger door, and the switch that ended up being the culprit for the door ajar light and is now unplugged (black plug, not the grey one).
  #29245
Old 09-28-2014, 11:27 AM
Technologiq's Avatar
Technologiq
Technologiq is offline
My driver side seat has seen better days. Trying to decide if I should replace the foam or just replace the leather? Was going to order from TheSeatShop.com. Anyone recommend if the new foam is worth it?
  #29246
Old 09-28-2014, 11:49 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I've been debating replacing my seat bottom cover, my foam is good as far as i can tell (still feels great) so that thought has not crossed my mind. I suppose if one was to be removing the seat and pulling it apart maybe it would be a good idea to do it all at once..
  #29247
Old 09-28-2014, 12:01 PM
el-lobo's Avatar
el-lobo
el-lobo is offline
replaced the wiring harness. that was an expensive one.
  #29248
Old 09-28-2014, 12:46 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
I am upgrading to the '05 headlights. The ones I got had the chrome housing, so I had to take it apart and paint the bezel inside. It has been a pain in the *** getting these damn things in there. I knew it required a lot of cutting....but DAMN. I wish I had a corded dremel, this battery is only lasting me about 20 min, then takes about 2 hrs to recharge.
  #29249
Old 09-28-2014, 08:28 PM
Splash67's Avatar
Splash67
Splash67 is offline
Yay,I put her back together today...much to my surprise she started right up and drove it for the first time in a week...
  #29250
Old 09-28-2014, 10:50 PM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
Got it back on the ground. V codes are in ball joints are done. Massive amount of paint laid up front. All I can say is I LOVE THE V CODES
Quick Reply: What did you do to the X today?
