What did you do to the X today?
Old 03-12-2013, 10:34 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
OH MY GAWD!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #14252
Old 03-12-2013, 10:39 PM
AzPatMan's Avatar
AzPatMan
AzPatMan is offline
Originally Posted by wpnaes
While a neat concept - I think the looks are just not right.
  #14253
Old 03-12-2013, 10:55 PM
Karlsgems's Avatar
Karlsgems
Karlsgems is offline
Yikes. I think Tim should stick to Excursions. That just doesn't work for me.
  #14254
Old 03-12-2013, 11:38 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Anyone else have plastic hook that holds their floormat in place
  #14255
Old 03-13-2013, 12:11 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yes mine is intact and holding my rubber mat in place. why do you ask? lol
  #14256
Old 03-13-2013, 01:54 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
I went to shake the matts off and they wete holding that mats in! I thought someone added them
  #14257
Old 03-13-2013, 03:50 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
LMAO!
Stewart
  #14258
Old 03-13-2013, 05:41 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Mine are there, remember them well from when I changed the tube assembly in my steering column. Had a triangle shaped bruise on my shoulder for weeks over that little clip.
  #14259
Old 03-13-2013, 07:19 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Yup, mine are there and holding the factory mats too.
  #14260
Old 03-13-2013, 07:28 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Ditto here, they don't get much dirt under em so no need to vacuum under em.
  #14261
Old 03-13-2013, 07:31 AM
Snowseeker's Avatar
Snowseeker
With the spikes on the bottom of the mats I can't imagine they would move around without the clips anyhow. I know when I clean mine I have to pretty much pry them up out of the carpet.
  #14262
Old 03-13-2013, 07:36 AM
Archion's Avatar
Archion
Archion is offline
Powered up the camera last night. Decided to go with a switched power source in the rear hvac cabinet instead of the reverse circuit. I forgot to take a pic in the daylight with the hitch in, but it looked really good. Nice and clear picture. I did take some night shots. The first is with no lights, just using the inbuilt infrared LED's in the camera. Number 2 is with the brake lights applied, and #3 is with just the running lights on. Not horrible for 16.99.
  #14263
Old 03-13-2013, 07:42 AM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,160 Likes on 1,689 Posts
Not bad Matt, better than nothing.........
  #14264
Old 03-13-2013, 08:01 AM
Snowseeker's Avatar
Snowseeker
I never thought of that, is the image reversed? Is it possible to correct it if it is reversed?
  #14265
Old 03-13-2013, 08:07 AM
Archion's Avatar
Archion
Archion is offline
There are two types of cameras, one has in inverse image, which is what Pioneer calls for. If you were to put a non-inverse camera on the Pioneer, it would be reversed on the display. The add-on units we have in our delivery vehicles are switchable.
Quick Reply: What did you do to the X today?
