What did you do to the X today?
Old 07-11-2011, 11:27 AM
Paul T's Avatar
Paul T
Paul T is offline
Mine got cleaned to go to the 4th of July. She had fun.
  #767
Old 07-11-2011, 11:29 AM
Paul T's Avatar
Paul T
Paul T is offline
Here is another.
  #768
Old 07-11-2011, 11:41 AM
locknload223's Avatar
locknload223
locknload223 is offline
Originally Posted by VR6Nutt
The X was hard to start Sunday morning. Thought the kids must of left lights on or something. So went with the family to Home Depot. Upon leaving, no start! Friend gave me a jump. Limped home. Weird thing is no accessories worked at all, except A/C. Got it home and tested voltages. Was 7V coming from alternator. Got a new one from Autozone and a new serp. belt why I was at it. In the process I realized the geniuses at Ford designed the top rad hose to go thru the belt! WTH? Drained some coolant, removed hose. Back together now, charging properly. But my damn ABS light is on now! Any ideas?
I know it's too late now but you could have installed the Napa 9066 upper hose. It's set up for dual alternators and routes behind the hose. It wouldn't help you now but will next time.
Sorry, can't help ya with the ABS light, mine's on too. Could be a frayed wire coming from your the inside of your hub up to the plug (follow the line wire next to the brake and vacuum lines). Also could be a front wheel speed sensor or may be your rear wheel speed sensor on the rear diff (around $20 from Autozone).
  #769
Old 07-11-2011, 01:23 PM
VR6Nutt's Avatar
VR6Nutt
VR6Nutt is offline
Thanks. I did some reading postmortem and realized the alternate hose was available. Oh well - should be good for another 30-50k. I think Autozone has a scanner that can check ABS codes - I'll have to see if I can "borrow" it. I was wondering how a ABS light can trigger from power failures - or if its possible.
  #770
Old 07-11-2011, 01:31 PM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Received 4,679 Likes on 2,606 Posts
A low-voltage condition can actually wreak havoc on a lot of electrical components. But most automotive electronics is engineered to be very forgiving. Batteries and alternators will fail and it would be a public relations nightmare for all of the electrical components to need replacing just because a battery failed.
I wouldn't expect a complete coincidence here, but perhaps the ABS sensor was already marginal or the diagnosis/repair affected a wire or connector related to the ABS?
  #771
Old 07-11-2011, 01:55 PM
jd58980's Avatar
jd58980
jd58980 is offline
VR,
Check the brake fluid level. If the brake fluid is low, the ABS light will turn on. If the fluid is fine, wiggle or play with the float. Sometimes they stick and trigger the light.
Hope that helps.
( I have had this happen to both my explorers and excursion.)
  #772
Old 07-11-2011, 02:36 PM
jasonodsky's Avatar
jasonodsky
jasonodsky is offline
Spent Saturday afternoon pulling apart the rear interior to get at the rear AC. It's not working. Confirmed the blend door was working properly. I suspect it is the rear expansion valve. At least it's all de-dusted under the panels now.
Lucky me, I live in the only state that does not allow R134a to be sold to the general public. The shops get to charge $19.99 per pound.
  #773
Old 07-11-2011, 05:41 PM
Elmo154's Avatar
Elmo154
Elmo154 is offline
Changed Fuel Filter
Changed out the fuel filter today. De-pressurized the system but still got full of gas while disconnecting the fittings. Need a new approach next time.
  #774
Old 07-11-2011, 05:56 PM
jasonodsky's Avatar
jasonodsky
Same thing happened to me. I stunk like fuel the rest of the night. UGH!
  #775
Old 07-11-2011, 07:22 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is online now
Received 2,109 Likes on 560 Posts
Changed the idle air control valve. I know many suggest a cleaning, but for 50 bucks figured I would just change it out and be done with it. I never had much luck cleaning an EGR valve on other vehicles, course that's prolly apples and oranges.
  #776
Old 07-11-2011, 10:00 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
-Got huge pair of channel locks and tightened up my loose dip stick. No more slow oil leak
-Fixed my misaligned headlights...lost/broke the flat clips that hold the headlight in place. Instead of paying $28 at the dealer for 2 (two) clips, I spent $2.99 and used two hair pins from this assortment: Dorman Help! 93036 - Hair Pins | O'Reilly Auto Parts
Headlights are perfectly aimed once more
  #777
Old 07-11-2011, 11:47 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Wow, that's a tough one to watch go by without a comment Tor , but I better not...
  #778
Old 07-12-2011, 04:38 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i filled mine up and parked it and grabbed the expedition..gotta switch'em up they get mad if you leave them sit more then a week.
  #779
Old 07-12-2011, 06:35 AM
Toreador_Diesel
Retired Mod
I left myself wide open for that one...lol!
I could say something else, but since I'm a mod and this is a family oriented forum....
  #780
Old 07-12-2011, 09:09 AM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
...hmmm...you don't say?
Quick Reply: What did you do to the X today?
