I did it because both the starter and glow plugs are hard-wired to the passenger side battery and the higher amp altenator. My pass side battery was always weaker and the first to go. It also allows the driver battery to play an active role in helping the passenger side battery absorb these loads. You cant see it but both the power and ground are upgraded. FICMRepair has a great explanation and cables already made up if you dont have access to cables,connectors and crimp tool for wire this big. Not cheap though!!
That'sno lie but I think my rig will love the extra juice. My 230 amp and wire upgrade kit will be drlivered this morning. Installing that today, getting the Magnaflow muffler pulled off and replacing with a 4" delete pipe and hopefully getting my light bars installed in my new brush guard. I got the old bumper pulled off and replaced with a full replacement last night.
So am I understanding correctly that the kit is just larger wires?
It is a reroute, larger positives and a ground upgrade all to handle the extra output and help distribute the load between both batteries instead of the passenger side battery getting bogged down with the glow plugs and starter load. There is another ground upgrade I am going to do that uses a 72" 1/0 ground cable to also help distribute the load. I am headed to the mail box to get it now.
The larger wires handle the 230 amp alternator, the other two wiring mods distribute the load. Go to FICMrepair.com and check it out. The negative cable mod is on this forum.
I've been looking at their site for a while but they don't really explain with detail how it works but I think I get it now. The inter connect wire is what distributes that load because the truck didn't originally have that wire? Is that correct?
Incorrect.
Diesel engines need more juice to start, which is why there are two batteries wired in parallel to each other.
I suck at electrical so take this following with a grain of salt, but I believe the reason the upgraded wire kit works better than OEM is due to less resistance through the wire and better grounding, which the diesels electrical system respond to really well, longevity wise and performance wise.
Think he is correct actually Stewart, the 4/0 cable allows a more equal sharing of the load during startup - something that wasn't there in nearly the same capacity before.
So simply installing another bigger wire between the batteries helps them share the load better? Why not just move one of those big consumers, either the ficm or the starter, to the driver side battery so that there's less stress on the passenger battery? Wouldn't that work, if the original smaller gauge interconnect wire is still installed?
Well, there's always the possibility I read his post wrong (not like that's NEVER happened to me before ) but I do believe when he asked, "because the truck didn't originally have that wire? Is that correct?" he wasn't asking about the size wire that was there from the factory. He was asking if there was ever a wire there at all, connecting them in parallel.
I think you're both saying the same thing actually. The bigger cable has less resistance and can carry more amperage thus allowing equal sharing of the load.
Stewart
I simply stated that incorrectly. I knew it was there in stock form just in smaller gauge. I should have been more clear. So I haven't looked but is that original cable connecting the batteries the same gauge as the cable coming from the alt to the passenger battery?
Yes.
Wow, if you think that's easier than simply upgrading the existing wire, you and I view things from a very different perspective where "logic" and "easiest way" come together. Then again, since I suck at electrical, maybe it's a lot easier for you to move a big consumer.
Also, that idea you've posited doesn't include better grounding for the electrical system of the truck, like the cable kit does.
Stewart
Reason: Added clarification thought
