What did you do to the X today?
I've used the u-joint press a lot in the past. Its just a large c-clamp you secure in a vise and use different size inserts to remove and install. If you take your time, 20 minutes is about right.
It's really not a hard job. It took me about a half hour to do both on my Lincoln, but I was going slow and figuring it out as I went.
on
Wrap a rag around it soaked in penetrating oil overnight first or soak it in a pot of it if you can.
on
So, My Ex has been going under the knife, getting a ton of engine work done. I just received an update from my mechanic, and here is what he has to say...
David,
Things coming along great, heads are at the machine shop, just waiting on them, tomorrow I'll do a few things like trans pan and external oil cooler, but after those i'll be waiting on the machine shop. I'm hoping to have her done for you on Monday the 16th but we'll see
only one "PIA" thing so far, the coolant hose tube off the front engine cover was corroded so bad I almost couldn't remove it (pic attached) luckily they're cheep but as you can see from the pic, there wasn't much life left, I'm surprised you hadn't had a problem already.
But things look amazing internally, all the cross hatches in the cylinder bores look like new, and everything is going smoothly. I'm doing a few other things for you too under my original quote; like Oil temp & pressure sensors (couldn't put myself to install old sensors in this nice and shiny new oil cooler by pass housing, and ICP sensor which is a PIA to do with out tearing down 1/2 the motor if it fails, which they commonly do.... ford was smart mid 04 to locate it on the passenger side valve cover they fail so much.
But other than that things going good, hope you have a great weekend!
Here are the photos he sent.
Having a good, professional and caring mechanic is a thing of joy! I can't wait to get my Ex back, it will look the same, but be healthier than ever!
David,
It can be done. I know at least three people here that's have removed and replaced they heads on their 6.0.
It's a little tricky - but not that bad from what I hear.
Really not bad for a little family owned two person shop. Just him and his wife wrenching away.
If anyone is interested in a good mechanic out here on the northern Oregon coast, here is his webpage: Seaside Muffler & Off Road
and facebook page: http://www.facebook.com/pages/Seasid...32267233489258
