they came with a pigtail adapter to work with 2000-2001 models. 2002+ models don't need the adapter. your 2001 will need to have the blinker wiring routed.
Thanks! I'll have to look into this. If possible I'd like to get the power telescoping and folding set. However, I have a feeling the price for that is a bit higher if its even an option for my year. Thanks Again.
My Lie-O-Meter doesn't work but I just returned from a Florida trip and got a hand calculated 17.2 mpg for the trip...best tank was 19.0...not too bad for such a big truck.
i came thissssss close tonight to ordering 08-up towing mirrors. the $87 shipping was a bit of a hard pill to swallow but.. i think the $447 wasnt bad. ball joints first then i'll do the mirrors. so very tempting though!!
$447, Russ? Which ones were you looking at? That sounds about $100 bucks too much.
If you want the power telescoping mirrors, you'll probably have to go with an OEM set. I'me not saying they don't exist, but I've yet to see an aftermarket set that had the power telescoping feature.
Just installed my RAS, it gave me 3/4 inch lift in rear with zero air in bags. Been driving her with full tank of fuel and 15 lbs of air in the bags. ( about 1 inch gain).. Rides much smoother than using the airbags to gain the 1 inch I wanted to achieve. I'm very happy with this setup, I'd never heard of anyone else trying it so WTH was my attitude. Glad I went for it.
Stewart
I think your speed reading got you again Stewart! Russ is talking about the $359 1AAuto.com mirrors plus the $87 shipping to him up in the 49th state. Dogsled transort isn't cheap!
I removed, repaired and reinstalled my drives side door lock actuator It hasn't worked since I got the truck last year and it's SO nice to have it. I stood there in my driveway for like 5 minutes just screwing with it once it was done
Don't the air bag manufacturers say to keep at least 5 or 10 PSI in the bags to prevent some sort of damage?
Tom, you are 100% correct... I just aired down to zero for the measurements, but I have to maintain at least 10 lbs while underway. Rides smooth up to 20 lbs. I wouldn't lie to ya
They provide extra leverage on the frame when pulling a trailer, and in extreeme cases, can bend the frame a bit.
I'm with you on this, my new to me EX had them on. Figured I would leave them on and only use if towing with some stupid heavy tongue weight. ( I hate the Pre-runner look and Prius too ).
I just let the *** end sag with heavy loads. Doesn't matter to me. Before I redid my rear springs, it would sit on the bumpstops quite a bit. With my new springs I put in, with 750 lbs on the ball it only drops about a inch.
