What did you do to the X today?
Old 11-11-2010, 03:11 PM
hhcobra's Avatar
hhcobra
hhcobra is offline
Flushed the power steering pump with 1.5 quarts of Mobile syn. ATF. Brake pedal came up about 1 inch and pump quit whinning[sp]. How much were the new mats?
  #152
Old 11-11-2010, 03:20 PM
CrzHelm's Avatar
CrzHelm
CrzHelm is offline
just did my ball joints. wasnt too bad at all. glad i did it my self. thanks to those guys for taking the time to post those balljoint write ups everything went smooth.
  #153
Old 11-11-2010, 03:46 PM
slenser's Avatar
slenser
slenser is offline
You flushed your power steering pump and it affected the brake pedal?
  #154
Old 11-11-2010, 06:44 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is online now
My brakes improved quite a bit after the flush as well.
  #155
Old 11-11-2010, 06:47 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
just got my lift shackles in, may go install them...debating.
  #156
Old 11-11-2010, 10:28 PM
1NiceHarley's Avatar
1NiceHarley
1NiceHarley is offline
Greased the front steering locations. Lubed the drivers window. Removed an old phone system that was in the truck.
tomorrow: going to look at the rear door switch
Saturday: going to get the windows tinted.
  #157
Old 11-12-2010, 12:37 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
topped off my rear diff fluid.
  #158
Old 11-12-2010, 07:09 AM
twisstedex's Avatar
twisstedex
twisstedex is offline
if im not mistaking the desle trucks run on hydro boost so yes the ps fluid would efect the brakes....at least thats how my rollbacks are set up and one of them is the international with the 7.3....i hate hydro boost bec if the truck isnt runig or u loose ur belt u have no brakes.very scarry situation to be in trust me been there
  #159
Old 11-12-2010, 07:11 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
actually you have 3 or so pushes of the pedal left, that what the small canister is on the hydroboost its a reserve
  #160
Old 11-12-2010, 07:57 AM
Snowseeker's Avatar
Snowseeker
And it is pretty much the same for gas trucks with vacuum boosters. If the motor quits running you only have a couple pumps till the vacuum is gone.
I don't mind the hydro boost. at least it eliminates the belt driven vacuum pump that used to be on older diesels. I am surprised ford still uses a vacuum pump for heater controls. Just do away with all that and use stepper motors like everyone else.
  #161
Old 11-12-2010, 11:47 AM
slenser's Avatar
slenser
slenser is offline
Huh, I guess you do learn something new everyday!
  #162
Old 11-12-2010, 03:14 PM
mark996's Avatar
mark996
mark996 is offline
Well, in the past week I've had a lot of things done..
2 COP's changed
Plugs and boots changed
Oil Changed
Oil Filter, Fuel Filter changed, Air Filter changed
And, to hopefully end the week of things failing...last night the Alternator crapped out, so this morning I ended up changing it out. All is well, things are good in the hood again.
  #163
Old 11-13-2010, 01:28 PM
EMC V10 X's Avatar
EMC V10 X
EMC V10 X is offline
I replaced the rear brake calipers, rotors and pads, Used Napa calipers (and caliper brackets), Autozone Rotors, and Hawk pads. I also flushed the system. She stops WAY better now. I also fixed the door ajar switch in the back liftgate. It was much easier than expected. Then I took apart and lubed the front autolocking hubs. Next weekend or the weekend after I will attempt the front brakes.
  #164
Old 11-13-2010, 04:26 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Today my truck mind ****ed me....
For last few months, injector #1 started having issues where it seemed mechanically the injector was done. I ran some Rotella T6 and it seemed to fix it, but thought I would pull the valve covers anyhow.
Well...
I pulled both covers checked the harness and connectors, unplugged the harness while the truck was running to verify, and everything checks out. I put the truck back together take it for a drive and then the same problem happens again...
I planned on changing the injector, but decided against it since it decided to run better and get better mileage. Now I'm kicking myself wishing I would've just changed the inejctor and just let that be that. Electronically it's fine and passes a buzz test when it wanted to, but mechanically it can't decide whether it wants to work or not...it's getting changed for sure next weekend.
  #165
Old 11-13-2010, 06:12 PM
59CRL's Avatar
59CRL
59CRL is offline
I just started doing some mods on mine, added a Billet Grille and a Brush Guard. Im going to add some fog lights to the Brush Guard next.
Quick Reply: What did you do to the X today?
