New Back up lights - Quick, Easy, & Cheap
#61
Hey thanks Ron. Found the fuse. It was a 10 amp. Replaced it and the back up lights automatically come on in reverse now!
Only problem is, now they dont come on with the switch!! WTF !!
Its like one or the other. When the fuse was blown the switch worked great. Now that I replaced the fuse, the switch doesnt work and the auto on reverse works great. I suppose it is more important for them to automatically come on in reverse but thats not the point. I installed the switch for a reason!
Any ideas?
Any ideas?
#62
I understand why the fuse blew in the first place. my diode wasn't big enough so it backfed but now i have a sufficient diode that works great. Yes, it is all hooked up to a relay. Look back in the post, it shows how i have it all set up. It really should work fine. I have no idea what the problem is.
#63
So I was talking about getting some AUX fog/off road lights put on and I did it yesterday. I mounted the switch up just opposite of my reverse light switch to make it all symmetrical. $20 light and a $5 switch. Couldn't be happier for the price. They look great and light up the road very well. Check them out!
#64
I ended up figuring out why the fuse kept blowing and why only one function would work. You need 2 diodes. One on the switch wire inbetween your stock reverse wire and the relay, and one for the switch wire from your actual toggle. It all makes sense now.
So I got some new LED tail lights. Love them. I even tinted them and got some LED 3157's for the reverse part. Now I am wanting to match the AUX back up lights to them. I already have the switch and relay ran, so it is just a matter of getting some good LED's to mount. Anybody know of where I can get some that would work well for back up lights?
Void All previous Diagrams in this thread. Use this one!
#65
#66
RON,
You need to tell me about the green in your headlights. When I saw it before I thought something was wrong with the photo. Now I've seen another picture and I see it is by design. What are they, how did you do it? That looks great and I may need to look into it.
Thanks,
JP
#67
on
nice job Bryce..looks good..
yes the head lights are/was green..i drilled a hole in the top of the head light housing to fit a 194 side marker socket..i then put in green LED flanks..the flanks made it hard to see inside the head light when the lights where off...i then wired them to the parking lights...my girl friend gave me the idea..i was putting in my new stix and 38R and she told me this truck was possessed and it controld me lol.... i have the 05 Harley lights now.pic in sig....not sure if i will do this to them yet..
#69
It wants that mesh stuff for the grill right now. I need to call Lowes today.
#70
on
no pix of how i did it...just find any old side marker light with a rubber twist lock socket for a 194 bulb...drill a hole the same size in the top of the head light...take a dremel and make the square slots so the socket can fit in and twist to lock just like a side marker light does...take a shop vac and duct tape a 3/8 gas line onto it then slip it in the hole you drilled to suck out the shavings...or just take the light out and tip it up side down....wire it up and your done....
#71
#72
on
I cant find the link right now for the flank...its a white flat chip with one clear to green diode..can be found in the 194 section..just can't remember what site it was.....I had one in each head light..that way the bright white light from the head light over powers the green....it doesn't even look like the green lights are on...here in NH colored head lights are illegal....I put them in the top of the head light and the green diode pointing into the bucket so the chrome mirror of the head light made the whole thing shines green..
#73
