2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Various Defaults on restart
Old 08-04-2010, 02:15 PM
Trucker22's Avatar
Trucker22
Trucker22 is offline
I tried a search and came up empty. Does anyone know if it's possible to change the default settings of the 'info center' on 2010 Navigator? When I tow I disable the backup aid (beeping when something is directly behind) but every time I restart it defaults to 'on'. It's a real pain to reset this three or four times on a days worth of towing a boat. Also the cooled seat setting defaults to 'off' on every restart--I'd prefer it returned to the setting I set before shut down.
Any ideas would be appreciated.
Thanks
Old 08-04-2010, 05:19 PM
glruff's Avatar
glruff
glruff is online now
My 2010 Expy is the same. Have you contacted the dealer?
Old 08-04-2010, 05:21 PM
berry1234's Avatar
berry1234
berry1234 is offline
I doubt there is a way to set the defaults. I have never seen or heard of this.
Old 08-04-2010, 05:27 PM
Trucker22's Avatar
Trucker22
Defaults
I was hoping to control these settings myself. And 'play' with them til I get them the way I want. I kind of like to have control and don't like some of the automated stuff cause they don't work the way I work!
I was hoping someone here has 'hacked' into it somehow---probably not likely. Just a thought.
If this doesn't work the dealer will be next. I suspect they have some control if they want to help. However I suspect the darn lawyers have gotten into the computer settings. I suppose if it were to default off for the backup alarms and someone runs over someone Ford would get sued. This way you can't 'forget' to turn it back on. So the emphasis is on reducing law suits, not making things user friendly. Too bad
Hopefully the dealer will help some. I don't mind defaulting to 'on'---but they bury the setting about 8 button pushes into the menu---the thing is meant to tow so why not put a backup alarm defeat switch on the control panel---one push to shut it off as you back up---then let it default to 'on'. But that costs money I suppose.
I have never thought of Ford being a leader in computer consumer electronics---only when they have been forced to by competition.
