Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-03-2010, 08:52 AM
2000F2504X4 2000F2504X4 is offline
Garage is empty, add now
2000F2504X4 is starting off with a positive reputation.
2008 Limited Rear Power Liftgate won't function.
Yesterday the power liftgate on our 2008 Expy stopped working. I have checked all of the fuses. The sensors appear to be working also, because I get a beep when the tranny is out of "Park". I can manually open the gate using the latch behind the plastic access panel located just below the pull strap on bottom of the liftgate. When the door is open and I push the button, I get the "Beep, Beep, Beep" warning that the door is about to close, but nothing happens. When the gate is closed and I push the button, nothing happens. I can hear a light click at the base of the actuator arm when I press the button. Any suggestions other than taking it to the dealer. I can change parts myself, but don't want to buy the wrong parts. Anyone know the diagnostic procedures for the liftgate function?
Thanks,
Tom
__________________
2008 Expedition EL Limited
2008 F350 XLT 4X4
  #2 (permalink)
Old 08-03-2010, 11:51 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
There was a TSB on this I think, but I don't have my Alldata access anymore or I would look at it.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 08-03-2010, 12:15 PM
Well I figured it out. It was all due to a low battery. We had our first 100+ degree day yesterday. The two year old motorcraft battery with 70k miles use has exceeded its life expectancy. There was enough power to start the car, but not enough for the liftgate. Liftgate wouldn't even open with the car at idle. Put a charger on the battery, and the liftgate started working. Got a new battery, and all is well. Too bad the instrument cluster can't tell me I have a low battery......
Later-
__________________
2008 F350 XLT 4X4
Tags
07, 2007, 2008, escape, expedition, explorer, ford, gate, hatch, liftgate, list, manually, open, parts, power, rear, tommy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
