Backup Sensors not Working - Light Always on
Gang,
I can't find anyone who has this "always on" reverse light issue. My searches show that most people with the problem only have it when they put it in to revers. Mine's broken but the light is on all of the time indicating it's not working.
I can go through the sensors, but I think the system only recognizes sensor failures when the car is in reverse.
What's my first/next step?
I really appreciate any help.
Yes, talking about about that...
Yes, the "off" light is always on, can't find discussions with this exact issue, most seem to only go on when put in reverse and the solution for those is bad sensors. This seems like tomething else but I don't know where to start.
ok... seems like 2 of us need help.
Gang,
Not a Sensor - Speaker
Guys,
In case this happens to anyone else, if the light is not illumnited until you put it in reverse, it is likely a sensor. In my case, the light was always illumniated regardless of being in park, drive, etc. My issue was actually a bad speaker. $20 and 5 minutes to switch out (PN# YC3Z-15K864-AA)
My understanding is that the computer only checks sensors when in reverse.
Thanks for the adivce.
The speaker worked fine until one day when the system stopped working completely and the "Off" light was on as soon as it was started.
I didn't think it was the sensors because that symptom is only an "Off" light when in reverse. Mine was always on. I had a buddy at the shop use the diagnostic tool and it said it was the speaker. If you have similar symptoms "Off" regardless of what gear, you may want to risk the 5 minutes and 20$ to replace it.
