truck shakes violently need help narrowing this down
#77
#79
this joint seal is broken doesnt hold grease, connects one bar to another behind it, this joint is on passenger side
this one connects underneath to a part on the steering knuckle I think its called, this is also on the passenger side near the picture above
this is a picture of the two bad joints so you can better see, also ball joints look great as you can probably tell
now this one is on the driver side I think his is tie rod end, PO mustve lied to me when he told me theyre brand new, I think what happened is these joints were all bad and the other day when I drove with the plow on it mustve annialated them,
please help if you know what these are, I tried todo my best explaining, I wish I could take welding/metal fabrication AND auto shop at school
#81
okay guys I got the wheels balanced and the truck rides alot smoother now, next up is fixing the tie rods and drag link bar, if you guys could please look at the pics above to tell me wether I need inner or oouter tie rods end? I don't know which is which, I'm in no rush for this, would like i squared away by mid august though, will hopefully have my leveling kit installed aswell so I only pay for alignment once
#82
#84
LMC Truck Parts - Page 121
However being an F350 it's *slightly* different in that the drag link attaches close to the passenger side where the F250's attach closer to the center. F350 is a better design in my opinion.
#85
hi ive read a lot in this column ...good info
i have an 89 f450 7.3 idi when i bought it it drove 70 mph anywhere i wanted to go but rather quickly it started to shake worse and more at about 40 to 55 mph when it first started i could feather thru it and go but now it comes quickly and the truck becomes uncontrollable.
i have done 2 things before this happened
1 blew a tire and have since put 3 new tires on and balanced all of the tires
2 i tightened the steering box gear tightening nut and put shims in the steering shaft steering is nice and tight with just a little play
any ideas?
any ideas?
Ryno327
1983 - 2012 Ranger & B-Series
03-21-2017 11:33 AM
