(Updated)Need some help on my i beam flip(Plenty of pics)
#31
#32
#35
Thanks, I see that most of the longer travel beam suppliers use a swinger style steering setup off the frame with front steer spindles.
#36
#37
I didnt think that there was any difference in the radius arms but I wasnt looking for any either. My truck dosent drive bad at all, it will actually turn itself back straight in a corner if you let go of the wheel. I will take another look at my radius arms and see if they have some caster built in, if they do, I may swap mine back.
#38
hey boss300 have you done anything else to yours.. when you do you should post up more pics.. how big a tire do you think you can clear up front, i was hoping for 33's on mine. but just with everything sitting in, it's pretty high. im wondering just how high this will sit when it's done..
#39
#43
Ok here they are. I dont know why I only remember to do this at night but here they are. They suck and I will try to get more tomorrow.
Picture of the stance.
Picture of the clearance for tires. This tire is a 31 1250 15. You can fit plenty more tire on. I will have no problems with 36s.
Here is a picture pretty much the same pic I made at the beginning of this thread. See it is nicely aligned
Here is another picture of the stance.
May I also add that I have personally been in boss 300s truck and it drives perfectly fine. If he would have told me that it had a real lift on it i would have believed him. So as far as people speculating, the twin i beam flip is perfectly possible and does not give up driveability.
