ODB1 fault code 95- HELP please!!
#31
ok Bill i did the eec test with #2 and #6 connected with a wire and the brown wire had power with the key on. I also did the eec test with one end of the wire in port #6 and end the other grounded the other to the frame-body and the brown wire has power. Both times the relay clicked. How do i check the ecm power pins? what color wires would they be? i dont have a pinout of the ECM for my 1988 f350 460 auto tranny 2 wd. i hope im not comng across as being impatient just frustrated. The other day we jumped the power from the battery to the wires at the switch going to the intank fuel pumps and It showed we had power to the fuel pump connector but when we put the light on the orange ground wire -Nothing. The black ground wire to the sending unit part of the pumps work though so i was thinking a bad ground from the intank pumps "orange wire" and also a NO power situation from the brown wire coming from the fuel pump relay to the switch. So im trying to solve the brown wire situation first, then the ground problem from the intank pumps second. After explaining this situation to you do you still think the ECM is bad?? i would hate to buy that and find out its not the problem. remember that every thing in the whole fuel system is new and has been replaced and i have multiple parts for checking
Thanks Again Bill
Thanks Bill
Thanks Again Bill
Thanks Bill
#32
#33
It sounds more like a bad computer or a bad wire from the the EEC self-test plug to the computer.
IF you were jumping pin #2 to pin #6 of the EEC self-test plug then computer should have a good ground. If you were just grounding pin #6 of the EEC self-test plug someplace else then the computer could have a bad ground (computer pins #40 & 60).
You also need to check if the the computer has power with the key on (computer pins #1, 37 & 57).
The computer uses (grounds) the same wire from the self-test plug to the relay that you grounded so if it worked grounding pin #6 of the test plug then the relay and socket are OK.
Bill how do i check the eec test wire to the ECM. should this have 12v with the key on
Larry
#34
If you can not pull codes from the computer and it does not pull the fuel pump relay in for one second it says the computer is not working or working right.
Now you need as I said above check to make sure the computer is getting power and good grounds on the proper pins.
larry
#35
If the PIP sensor is not working you will not have spark.
Do you have spark at the spark plugs while it is cranking?
If not the computer may not be receiving the PIP pulse from the Distributor.
No PIP pulse to the computer then the computer will not turn on the fuel pumps or fire (ground) the injectors.
#36
Larry
#37
#38
Thanks again buddy because of all your suggestions this might be figured out
Larry
#40
bill im hoping its the ECM ground. On my truck the 2 green wires w/ the black stripe go into a connector then into the neg post of the battery. Im going to cut the connector out and solder the wires together and then attach them to the neg post of the battery. Ill also add a ground from the neg terminal to the body also. Im keeping my fingers crossed
Larry
#41
#42
Well F--- im back!!! as i was driving the truck the same symptoms happened within 0ne block. Im giving it gas and no power -no fuel pressure- spark- i havent checked yet but i know thats south too. When i thought it was fixed i was starting it up at least 25 times and i let it idle for 5-10 minutes several times - No problems!!! as soon as a load is put on the motor these symptoms come right back. What do you think Bill ECM ???. I just cant for the life of me figure out what this problem is. I just dont understand why the ECM is seeing the PIP count when it idles but not under a load. This same symptom has happened with 2 distributors and 3 tfi modules so i doubt its that. Please help i need this truck running soon. I have checked and double checked and triple checked my grounds
BigLar
BigLar
#43
#45
