overhead Console upgrade
>Ditto that! Great question! Looking forward to the replies
hmm...... I hope someone has done this!!!!! I would love to have one too!!!!!!!!!!
Justin
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9313&.jpg
http://members.lycos.nl/dukesofhazzard/dukeslogo.JPG
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler. Superchips microtuner.
My imagenary friend thinks you have a mental problem
Justin
I remember someone back in... maybe... June, that was trying to get all the parts together to install one. With any luck, maybe they are still reading the boards and will reply.
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Matt
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33695&item=1875453 824
Is this like them? I have never been in a Lariet truck yet?? hmm... you really got me thinkin now more mods I cant afford
Justin
Justin
I e-mailed Bubzilla, He is the one from that old post that was going to do the install. hopefully he will e-mail me back.
Thanks nafizmo for that link
Justin
Justin
Justin - The Exped. console eBay shows is not the one in the SD Lariat.
The Lariat for one does not have all the rear A/C controls like the
one here on eBay.
I will take a picture tmrw. of mine and post it... too late/dark out now to make a good photo.
I would think the main issue on how to make it work is not hanging
it up in the roof, but rather running the correct wires to it for
power and DTE readings (distance to empty) etc. That IMO is the tricky
part.
-- Bob
>cant afford
>Justin
2001 F250 SD CC Lariat, V-10, 4.30, 6' Bed, 4x4, Auto, K&N FIPK-2, SCMT-tuned, BFG 295/75/16 AT's
one here on eBay.
part.
-- Bob
>cant afford
>Justin
Here is the 2001 Lariat overhead console. Basically just the computer
readout screen and a small storage slot behind it.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=11537&.jpg
-- Bob
-- Bob
This is the e-mail he sent back to me....
Justin
Sure did, every thing except the temp sensor and cable that mounts somewhere by the radiator support. The temp reads "-40 C" (or "-40 F", it didn't matter) but everything else displays and works just fine. I especially like the "miles until empty" readout and also the computed miles per gallon is cool too (very accurate, too). I've got to find where the temp sensor and cable hook up to so the project is complete. The three dealerships I've talk to were little or no help and want to charge a bazillion dollars an hour to do this for me.
It took about an hour to install the interior pieces. I removed the pull handle and right A Pillar moulding, the right kick panel and the right sill plate. I then removed both sunvisors as to allow the head liner to come down just enough to plug the harness anchors into the windshield's frame. The harness also incorporates the power plug for cab lights so if you're not doing those just tape the connectors to the harness. I disconnected the battery when I plugged the harness to the connector located behind the right kick panel. I then cut the hole where the console fits; start small as I'm sure a crewcab headliner isn't cheap.
Patience is key; if you get frustrated stop and have a cool refreshing beverage of your choice!
Justin
Justin
Justin
Acc. to the tech. I spoke to at Ford this AM the harness is a separate
purchase and has to be wired in. You should be able to order it from your
local dealer.
hth,
-- Bob
local dealer.
hth,
-- Bob
