Harmonic Balancer - Balance
C3AZ6375L .. Flywheel (Flexplate) 157 teeth / Use with C4 transmission / Obsolete
Fits: 1965/68 289 / 1968/76 302
This should be EZ to find at autoparts stores, but if you want a gen-u-ine Ford original, I found dozens of them at FoMoCo Dealers, obsolete parts vendors.
The last MSRP was $245.83, dealer net cost was $147.50. Because the part is obsolete, the dealers can no longer return it to Ford, so are STUCK with it.
DON SANDERSON FORD in Glendale AZ has THREE (623-842-8762) and usually sells obsolete parts at below their original net cost.
There is another flexplate that has 164 teeth. It was used in full sized Fords with 289's and FX Cruise-O-Matic, and on 1978/80 302's.
Note the edited in info regarding I-6 flywheels in post #
AutoZone.com | | Flywheel - Automatic Transmission | FLYWHEEL ASSEMBLY
Ok this is what I ordered from autoxone, please let me know if it is the correct one please;
How many teeth does it have? 157 is correct, 164 is not.
Thats the one, if you click on the picture it has a discription of it and it shows the part number. It is the same as the number you posted earlier... Thank You
Here's a good article...... has a pic of the difference between 28 and 50 oz dampers
Eaton Balancing Engine Balancing, Part 2
Tom
FlyCool5.0
07-29-2012 10:49 PM
