I should be recieving the pump within the next day or two. I know not to epect huge differences in it's performance but I will be relieved knowing my injectors will be treated the way they deserve
I noticed a pretty good gain in power, along with no more cel. I have come to the conclusion my 15* was getting a little weak though, I set a cel pretty easy.
our mods are pretty close. i never set a CEL, just a fuel filter light if i really mash it, but it goes away as soon as i let off.
I would love to run a daul HPOP setup like that, and I thought thats what it was was a internationall 444 where they took the power steering pump off and put a HPOP on top then I read where william said QUAD so I looked at it better... lord have mercy you could use that for injectors the size of a horses slong and still have way to much oil...
I've never had the fuel filter light come on, like I said though the cel was set pretty easy. Jim did tell me though that the 15* can't keep up with the stage ones and a chip. No issues now though.
look for the fuel pump hole in the valley of the engine first. if it doesn't have one then it's an SD engine.. then you gotta figure out if it's an E99 or L99. for that you'd look at the intake plenums. 3" plenums would be L99 and 2" plenums are E99. E99's still had 15* pumps.
