You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just purchased (3rd owner) a 1982 Ford Class C motorhome built on a Ford E350 cutaway chassis with 58K miles. The engine is the 4bbl carburated 460 big block with a dual fuel LPG conversion. The conversion has large tanks on either side of the chassis and appears to be a professional if not factory installation in the engine compartment. The fuel gauge and dash mounted propane-to-gas switch is mounted in a clean but DIY fashion. There are no identifying markings on the readily visible components. The propane regulator/converter doesnt have the same ports that I see on the Impco Model E units on eBay. Specifically, there is an electrical plug with multiple wires on the left side of the unit going into a recepticle that is cast into the body of the unit. The rear of the unit has a roughly 1.5 inch long cast domed projection with the output line to the carb/mixer coming out of the center top of the dome. None of the regulators/converters I have been able to locate have electrical connections. The embossing on the back of the regulator is hard to make out observing it with a mirror, but it seems to be an oval and I could easily convince myself that it was a Ford logo. Can anyone help identify the manufacturer of this conversion based on this limited information? I know Ford supplied factory dual fuel units, but I have been unable the locate any manuals or other info to suggest that they so equipped the 460 engine. Any help would be greatly appreciated.
Anyway you can post a picture. It could be a century m6
regards
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
