Run without SPOUT connector plugged in?
I appreciate that! Im no mechanic by any means, so it helps when you hear an "atta boy", especially on something you know very little about.
It might be very beneficial because I also have a 92 diesel that has OBDI as well. It would work for both trucks.
BTW: What bolt do you loosen to adjust the distributor to set its timing?
on
There's a single bolt into the block at the base of the Dist. shaft.
If you get the attention of some of the older boy's, don't take their advice lightly. Those "Rep markers" are there for a reason. Trust me, they're not that easy to get! https://www.ford-trucks.com/forums/9...icons-for.html
Lucky for me, I did a hard self test. I counted my codes the hard way...several drawn out times to make sure I counted right. After 3 different days of tests, it about made me sick . I have ADHD, so counting those codes were especially difficult, but I got them down and confirmed a few times so that I was sure what the truck was trying to tell me. I like this better anyway because getting a machine to test is like trying to pass me a message through a third party on the phone. Info gets mixed up when passed through someone else. This way the truck told me what was wrong with it.
I think I will take my chances with you guys and go ahead and replace the TFI. Still not sure how to set the timing though once I get it replaced.
I also own the type of code reader that ymeski was suggesting to you. It's cheap and super easy to use. Once I used it more than a couple of times I got the process down and it takes me very little time to run the self tests with it.
One thing I will suggest is having an extension cord so you can operate it from the cab as you will need to test a few things for the computer during the tests, just like you did if you were to run the self test w/out a reader. You don't have to buy one- I made my own using 3- 6 foot lengths of 14 gauge wire. If clicking the link below doesn't work try copy and paste.
http://mystyk3.tripod.com/extension.jpg
Good luck!
on
I can feel your pain as well... kind of. I don't have ADHD but I am dyslexic- trying to count those codes by the engine light was like putting an elevator in an outhouse- it just didn't work.
Good luck!
Good luck!
So, I found a place where I could take a test to be sure, and have lived with it since. It actually works to my advantage in my job- I'm a truck driver/freight handler, and being able to "generate" a 3D picture how a truck load is coming together in my head helps me to better load the truck and make sure it's proper for transport.
I know what you mean about the effort tho- I think a large part of why I'm as literate as I am today is because I grew up not knowing I had dyslexia, so instead of "having to deal with it" I just made it work for me.
on
Well, to be honest, I didn't even know I was dyslexic until I was 19 or 20. My mother mentioned in passing that my father is borderline dyslexic, and after doing a bit of online research, suddenly my school years made so much more sense to me.
spout
I was having a timing problem as well, I could hold the timing light on the harmonic and watch the timing mark move back and forth, no power while trying to accelerate and a bad miss in the engine. I thought all was lost in my old pick up then I learned about this magical spout connector! I unplugged it started the truck up and the timing mark stayed in one place for 5 minutes a hopped in took off she ran like a champ, I am unable to pin point the timing issue I am having so I am just going to leave the spout disconnected and hope for the best :-) suggestions are welcome I just thought I would share my spout success story as well
on
PIP sensor/ Stator: Fuel Injection Technical Library » Stator (RPM)
#30
Hey guys. Me again. So I messed around with the wiring, cleaned everything up a bit and still no help. It is apparent that there is definitely a voltage problem somewhere. Until I get this sorted out, I have unplugged the SPOUT connector for the time being. Will it damage my engine if I drive it without it plugged in? At park anyway, it sounded much better with much better throttle response. I wanted a second opinion before I drive it anywhere as is. I figured it would be better than driving it with the off-timing that it was at.
There was, at one time, a TSB from FORD dealing with the wiring harness from the TFI to the computer shorting out.
It was a matter of opening up the harness/bundle of wires near the computer plug, and looking for a bare wire that had cut into other wires insulation within the harness.
Simple fix if that's what you've got going on.
Bob
