patch a leak in plastic fuel tank..any ideas
I picked up another 79 350 camper spec lariat this weekend and both tanks leaked. I replaced the front steel tank no problem. The rear however being a camp-spec is that kind small deep plastic tank. (I have 6 or 8 of the flat square style but naturally none like this) I bought some "water weld" (made by JB weld) at the parts house . It said good for fuel tank repair. I applied it as per directions and it held 2 days and went to leaking. It has a small slice in the bottom corner bout the lenght of your thumb nail. Has anybody had any luck patching one of these and with what product.. thanks John
None in particular. I have some $6 "The Original Super Glue" brand epoxy from the Home Despot that comes in a twin syringe. Air-drop a dollop on a piece of cardboard then start mixing. I use a wooden coffee stir stick. Remember, you'll have to work relatively fast. Lastly, I also recommend lightly sanding both surfaces to give'em some tooth.
I do plastic repair and fabrication a lot. I'm an interiors guy. There is no way to fix a plastic tank unless you can sand up the plastic, apply a urethane or epoxy based patch, reinforced with mesh. If the leak is on the bottom of the tank you'll have to drop the tank anyway, probably. plastic tanks are supposed to be cheap and disposable. I'd get a new one.
Determine if it is Polypropylene or HDPE and get the associated welding rod, permanent fix. Plastic Welding Rod
This may not be the best method but I had a leaking plastic tank on a Vw I bought one time from someone drilling down through the trunk. Mine was sorta like a crack rather than a hole. What I did was took a bolt more than large enough to cover it and cut 4 flutes to make it like a tap. Drilled the hole a little bigger so I could get it started. Once it was in I roughed the plastic up then put a good coat of orig JB weld over the whole mess. Never had a problem.
silverorange
04-25-2017 08:45 PM
Derfus
11-10-2016 12:41 PM
TheBlackBeast86
06-05-2016 06:41 AM
Mzaremba
04-12-2016 01:50 PM
Resendiz
12-01-2015 11:07 PM
