17" Lightning wheels on the '88 4x2 F150
If you put a low profile tire on the truck it will lower your towing capacity, you'd have to find out the load rating of the tire. I also assume that you are going to lower..or have lowed the truck. That also reduces your towing capacity as there is much less suspension travel.
__________________
Justin- FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
87-96 Forum
