Fuel Sending Unit / Fuel Gauge Issue (Updated)
The parts are the same, you will need to go into the parts catalog and look up the sending unit for the V10 and go from there.
Ok, I am possibly very lucky. I pulled the bed (only had to cut 4 bolts) and pulled the sender/ pickup assy from the tank and the float and rod were laying in the bottom of the tank. The sender still works though. I put the rod back on the sender and added a nut to the back of it to keep it from coming out again, even though the clips on the sender did snap good on the rod. Also added a washer and nut on the end of the rod to keep the float from coming off again. I ohmed the sender several times and all seems well, will know just how good it works once I drive it some and dont have a full tank anymore.
99 powerstroke fuel sending unit
bdrummonds, wuld it b possible for u 2 put the part num here for the pump. Ive tried looking 4 it up on partsguyed's site, but cannot find wut im looking for. And before every1 flames me over my spelling, yes i do know how 2 spell folks, i just like my version of shorthand, just sound it out like it sounds.
Hey guys,
just thought you should know i just stumbled upon this discussion and before i got here i googled fuel sending unit ford excursion and it took me to an option for an o'riely auto parts and they provide either the whole pump and sending unit for 481.99 or 490.99 depending on your location and grade of part and it gave me the option for just the sending unit 157.99 in my area. maybe this is something new that other auto places arent doing but oriellys are pretty common in wisconsin and alot easier to drive to get you part than wait online...not to sound like spam or anything hope this helps.
Hey guys,
Dont mind me guys, Im just searching the subject and came across this old thread.
My 7.3 has a bad sender. Has anyone tried the v10 gas float solution? I can get right one for $351 with the discount, but if I can save $200, Ill go for it. IF you have done, do you know the part number, or the PS number, I think the gas has the pump built in? or something like that. I dont know, I dont pay attention to gas trucks.
Fuel gauge problems
I'm sorry to keep beating this to death, but it may help someone else in the future. Due to getting ready for the new addition to the family (wife's due with our second this thursday), I haven't been able to do the hutch/harpoon mod yet. I have everything, but the time is the issue.
Well, to be ready (in case a couple hours presented itself) I've been keeping the tank kinda low. It's because of that, I've actually started to run out of fuel twice since I had the initial problem (that I mentioned in "IDM problems"). Fortunately, I have been near enough to a gas station to spit and sputter my way to there to add only another 5 gallons or so.
Here's my question though. Both times I started to run out of fuel, I have shown 1/4 of a tank. I'm just wondering why and if there is anything I can do to possibly fix this while I'm in my fuel tank with the sending unit out. It's like it's not really calibrated correctly, because the gauge works fine when it's full reading all the way down to the 1/4 where it's run out on me a couple times. Thanks in advance for all the help you guys can give.
#28
Let's start with the simple fix first ..... Disconnect both batteries (-) cables. Then turn on your headlights .... go have a beer or what ever way you want to entertain yourself for an hour. Turn off the light switch, connect the batteries, turn on your key, if the gauges go to 100% then to zero instantly you did a good job of draining the system. Now drive off and watch your gauge, it may move v e r y slowly but will eventually give a correct reading (if something internal is not broken).
I'm new to this truck and I couldn't believe how inaccurate the gauge readings were. At 1/4 tank I would put in 10 gal and the gauge would be pinned on F then down to 1/2 .... up and down all over the place. I did a battery disconnect and now I have a working gauge....... it moves very slowly after a fuel addition, but will eventually show a correct reading and then start slowly moving down as I put on the miles. This fixed my problem for a cost of 0$. This may not solve your problem but give it a try first ...what do you have to lose?
#29
Was wondering. Do you use the entire sending unit or just the electronics of the sending mechanism?
The bracket that the unit is mounted to looks diff than the factory for my 2000 F250 super duty 7.3 29 gal tank?
Do you just use the actual plastic float sender and mount it on my current tube bracket? Confused.
powerfordf1504x4
04-19-2006 01:34 PM
