95 powerstroke oil leaking
Old 06-06-2010, 08:30 AM
strokin4x4's Avatar
strokin4x4
strokin4x4 is offline
i have a 95 powerstroke f-250 it has 211k miles on it i just did an oil change about a week to a week and a half ago but somehow it has leaked almost a gallon of oil between now and then. i usually park in the grass so i have not noticed it but i parked in the driveway last night and the was about a 6inch puddle under it this morning. im not sure where its coming from and thats the problem, it doesnt appear to be coming from the pan or oil filter but it also doesnt appear to be leaking from anywhere else ive always had a constant VERY small leak from the pan nut but never enough to have to add oil between changes. if anyone has any ideas of how to find the source of the leak or any idea of what to do about this please let me know.
Old 06-06-2010, 08:46 AM
Talyn's Avatar
Talyn
Talyn is offline
Pedestal, IPR, HPOP.
These will all leak on ya.
Probably pedestal leak, or IPR.
Old 06-06-2010, 09:26 AM
427 fordman's Avatar
427 fordman
427 fordman is offline
Ya you're gonna have to clean up top some and start it and see if you can find the leak. It's probably from up top, like william said. My bet is either the turbo pedestal or the plugs in the back of the heads.
Old 06-06-2010, 10:29 AM
1997F-350's Avatar
1997F-350
1997F-350 is offline
if it turns out to be the plug(s) in the head they are way cheaper at IH...than ford. replaced one on my dads truck
Old 06-06-2010, 02:36 PM
fixitman1310's Avatar
fixitman1310
fixitman1310 is offline
have you checked the oil cooler drivers side under powersteering pump and manifold
Old 06-07-2010, 07:04 PM
wetsailor's Avatar
wetsailor
wetsailor is offline
If this is eng oil and not fuel,I had that prob, mine was where the dipstick enters the pan, there is a round metal pad that connects with a very large nut. there is an o-ring INSIDE the pan that goes bad. Sometimes tightening the nut will stop your leak, otherwise, you must replace the oring. This can be done without dropping the pan, but look up how to do it on this forum or pm me and I will see if I can find the link. good luck.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-06-2015 01:51 AM
Eddie C
07-22-2014 03:28 PM
Eddie C
04-30-2014 06:43 AM
Carnes99
Modular V10 (6.8l)
02-06-2013 01:22 PM
farmnfly
35
06-12-2011 09:05 AM
Quick Reply: 95 powerstroke oil leaking
