I am in need of a EGR carb spacer plate for a 460.It doesn't have to have a EGR valve on it, but I would like for it to be in fairly good condition. If anyone has one they don't need let me know.Thank guys
You can get adaptor plates that block off the EGR.. Is this on a "quadrajet" style (two small holes in front and two big holes on back) intake manifold that originally had the motorcraft 4350 carb? I had a 460 that had this style manifold.. I stuffed a small freeze plug into the EGR hole and used an adaptor plate.. Worked fine
I have the quadrajet style manifold. What size freeze plug did you use? I just got a new carb and riser plate. I'd like to put it on tonight.
OK, I found them...BUT it will not work if you plan on keeping the Motorcraft carb. It is a Holley SQUARE BORE to Motorcraft 4350 EGR block off adapter.
