'74 F-100 Build thread "prerunner" (desert truck) LOTS of PICS
#78
Sorry guys - not sure how I missed that there were new posts. I came on to do a slight update and saw the below so I'll answer those 1st.
See below.
You keep bugging me every 5 minutes and I'll tell him to take his time. Or you could just do them yourself - but wait - that would take you even longer than he is
Not really. Oh wait - you mean his response will be interesting when he sees it. Yup, it will
For the ranger. It is the project I never finished and where most of the parts for the supercab are coming from. As for the "shape" of it... It's good or bad - depending on who you ask.
In order to keep this short and try and stay on topic I'll just post a couple pics. It still sits how you see it in the pics and I'd pretty much gaurantee you no one from this forum will buy it or would know what to do with it
Now back to the topic at hand.
No work on the supercab last night. I got my new bolt bin back from powdercoating so the last couple nights have been spent playing with my nuts... and bolts
The bolt bin is 1/2 the size of this one and sits on top of it. I lowered the stand on this 9 1/2" so just a milk crate fits under it now, but I look eye to eye with the bottom row of the upper bin. Time to set the bottom one on the ground or leave a step stool by the thing Both bins are preety much packed - TONS of grade 5 and grade 8's in there
So enough about my nuts and back to the build.
I spent a little more time today playing in cad and drawing more of my brackets for the "temporary" seat mounts. These will bolt onto the stock sliders and will hold 2 beard style seats and most likely a center console. It'll stay that way until I cage the thing and build seat mounts off that.
Tonight I'm going to look at how my templates for the seats look and then look at if a 33 gal. tank out of a bronco will easily pop in place of the rear 19 gal. tank. After that I've gotta spend some time on the '72 alfa as it has been left neglected for far too long and I finally got the brake line I had been waiting on for it.
See below.
#79
#80
The plan is to try for 4 eventually. It may go to a smaller bench in the back that can fit 1 regularly and 2 if needed - or worse case scenario 3 buckets.
For this 1st go-round with getting it running it'll just have the 2 front seats. If I get adventurous I'll look at throwing 2 in the back - but I'm thinking those won't come in until the cage does.
#81
I know the crossmember on my truck isn't up to your quality but it was quick and easy.
#83
I believe the frame is different between the 73-79 to 80-96 but this is a link to how it's done on a '90's p/u :https://www.ford-trucks.com/forums/7...-tank-mod.html
And as for the Supercab update - I got nothin. I looked at the seat mounts and need to make some adjustments. Looked at the 33 gal. bronco tank and it's too much effort for a temporary solution.
I got distracted organizing my bolt bin a bit more last night (it's still not done either). Because of that and because I was having some issues running the speedo cable on the alfa I didn't get near as much done as I wanted on the alfa. Therefore tonight will be another alfa night after I look briefly at the seat mounts again.
#84
Ya, but at least there is no drama like DR on here, well at least not as much.
#85
That's a big part of the reason I didn't post the build there. I may post a few pics when I'm done but that's it.
The other reason for not posting the build there and on RDC is I frequent (meaning read/post in daily) 6-7 forums. I couldn't keep up with posting the build in all forums so bits and pieces of it are going everywhere
#87
#89
