Spare Tire Conundrum
Old 05-25-2010, 06:24 PM
PassedDown66's Avatar
PassedDown66
PassedDown66 is offline
Question Spare Tire Conundrum
On my flareside 66 there is no provision ( as the truck came to me anyway....) for a spare tire. As I am Mr. Murphy's favorite guinea pig I would like to fix that.
I know I could just throw a mounted tire in the bed, although that could be a very easy thing to steal......
Are there kits to mount one inside the bed? I have seen older ford flaresides with a fender shaped in such a way as to mount outside the bed but I dont know if that was something that was available in 66 and I dont want to change my fender anyway.
Is there some sort of kit to install a under-the-bed style on these trucks?
Is there a later year model whose under-the-bed system fits or could relatively easily be made to fit?
Thanks!
Aaron
Old 05-25-2010, 07:17 PM
Rusty 63's Avatar
Rusty 63
Rusty 63 is offline
I've seen (on here) guys that have retrofit newer crank-down spare tire holders under the rear of the bed. The stock setup was kinda bear of a bolt up affair (you're not getting it down without getting filthy). I plan on going the crank-route when I get to that point. If you use the search feature I bet you'll come up with some options.
Old 05-25-2010, 08:11 PM
Rusty 63's Avatar
Rusty 63
Rusty 63 is offline
https://www.ford-trucks.com/forums/7...ml#post6345365
That's what Carcrafter22 did on his. The search for "spare tire" in the 61-66 & 67-72 forums turned up 17 pages of results... Search & read & let us know what you decide.
Old 05-26-2010, 12:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The crank down spare tire holder was first offered in 1973 as an extra cost option.
Believe it...or not: From 1925 thru the 1970's: The spare tire AND the wheel were extra cost options.
On 1953/79 Flaresides, Ford offered an optional left rear fender that had a cutout where the spare tire could be mounted, the other option was mounting it under the bed.
Old 05-26-2010, 05:28 AM
Old_Crow's Avatar
Old_Crow
Old_Crow is offline
I've got the optional fender, I just don't have the optional rack for the optional tire.
I need to find either the rack or a different fender. Anybody got one(preferably the rack)?
Old 05-26-2010, 10:27 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
Replaced 65 flareside optional fender and rack with an under bed carrier. Easy swap.
davewave649
23
07-17-2011 09:38 AM
truckbuff
08-24-2006 01:25 PM
murphy
08-18-2005 01:01 PM
murphy
09-10-2004 03:20 PM
Quick Reply: Spare Tire Conundrum
