Who restores interior door panels?
My 1986 F-150 Lariat has just gone through a restoration with the exception of just a few things,the main being that the interior door panels in the lariat trim are really hard to find.Just wondered if there was a resource for restoring these.The plastic near the top has faded and deteriorated from the sunlight.I have been able to find an aftermarket,but not one that is like the original and I want it to look original.Thanks
SEM makes an aerosol that is used for plastics, & carpets. find an auto paint store near you, call to see if they carry it. Comes in various colors. I think it is a 12 oz. can, about $12.00 per can. If you cannot find oem pieces. www.semproducts.com Hope this helps.
You can try and see if they have them here 1980-96 Ford Truck/bronco - Door - Door Panels 80-86.
If he has an 86 he needs some like this. LMC Truck Parts - Page 93
They reproduce power and non power window door panels, but I guess the don't reproduce the Lariet ones with the velour on them. That would be cool if they did.
There are several how to's around the internet about painting interiors. I see the paint to do it all the time in the auto part stores. I've seen pictures of people's work, and it looks real sharp. On my exes vehicle I repainted a interior piece, and it came out perfect! It was easy. It literally took about 10 minutes. If you do it yourself, then you have more of a choice of the color.
Check out LMC. They are cheep and good guys there. LMC Truck Parts - Page 94
I'm still going to suggest that the do-it-yourself spray cans would be best. There are tons of people who have come out with great results and for $290 less then LMC Truck.
I've used paint made for plastics, which is what i'm suggesting. And i've NEVER had it flake off. Actually I painted some plastic green chairs with it, and they're still the good looking red. Lots of weather and heat, and still no flaking or ANYTHING.
Ordinary spray paint WILL flake off, probably in a day or two, spray paint made for spraying onto plastic however, works much much better.
