donaldson Air Filter
What do you mean eventually it will be replaced? you mean when I replace it?
Any idea how many layers of media the air has to pass through? there can't be just one layer... I just want to make sure any small tears will not let dirty air though.
It doesn't really have layers. Imagine a piece of cardboard rolled up with the corrugated ridges running the length of the filter, in the same direction of airflow. The corrugation creates the airgaps between the rolled layers so you don't end up with a solid roll of paper. The filtered air never actually passes through anything. The dirt just gets stuck to the insides as it goes by. You can see daylight right through a new one..
Not quite so simple.
he principle of HEPA filtration is not to restrict the passage of particulate by the gap between fibers, but by altering the airflow streamlines. The airflow will slip around the fiber, but any higher-density bioaerosols or particulate matter will not change direction so rapidly and, as a result of their inertia, will tend to impact the fiber. Once attached, most particulates will not be re-entrained in the airstream.
That is the simplest description of the mechanism.
But in fact, there are more mechanisms at work:
Molecular diffusion
Inertia
Gravity
Interception
Straining
London van der Waals
Forces involved include Inertia, London van der Waals, Electrostatic, Viscous, Gravitational and Thermal
Inertia
Gravity
Interception
Straining
I believe you're fine with the creases...
PowerCore®Air Filters
Donaldson premium air filters that utilize PowerCore™ filtration technology for Ford 6.0L Diesel PowerStroke™ and GM H2 Hummer 6.0L Vortec™ plus other applications listed below. The rugged structure of PowerCore™ filters features an innovative, layered, fluted filter media, which allows air to enter an open flute while forcing it out an adjacent flute, allowing only clean air into the engine. Dirty air is effectively filtered and cleaned in only one pass through the media.
Like I posted earlier, I don't know much about them. AFAIK they're magic filters.
Actually, when we cut one apart, I do remember the engine side being much more solid than the inlet side. That must be where the air passes through the adjacent flutes like Moyock posted.
A top quality filter like that one will have a lot of "black magic" in it.
Carefully blended fibers to generate static electricity with air flow, mix of fiber densities, etc.
Coatings to tweak it.
None of this they will tell you --- nor is it obvious in a simple examination from cutting it apart.
If it is so easy, you would have the market flooded with Chinese made clones for $5 a filter.
