2005 Ford Ranger 3.0L V6 oil drip
Need help! missing piece, exposed tranny
Sorry to resuscitate an ancient thread, but I need to know the name of the cover that OP removed in the second photo he posted- the cover on the transmission that exposed the gear.
I just crawled under my truck to look for the source of a leak and that cover and both bolts holding it on are simply gone!
1996 Ranger v6 3.0 automatic
Any help in identifying that cover so i can replace it would be greatly appreciated. Thanks,
Photobucket does not like my old machine, but I expect the plate is the inspection plate on the bottom 1/3 or so of the bell housing. It keeps road 'stuff' from getting inside the bell housing, protecting the front seal of the transmission, and keeps stones and such from jamming the flywheel teeth against the bell housing.
If you need one, I'd go to a scrapyard. Shouldn't be hard to find.
Back in 2010, I would have suggested that the OP look at his oil pressure sending unit, as it is mounted atop the block and could be the source of the leak. The sending unit has a bakelite 'cover' swaged in place, and they can get loose, and pump all the oil out over time.
tom
tom
Y2KW57
31
04-08-2021 11:37 PM
slashfan7964
166
08-16-2020 11:08 AM
Blockfort
16
09-03-2016 10:34 AM
Maverick68F100
20
06-29-2016 11:36 AM
