How high is your 302?
on
Can someone give me some placement specs on your 302 engine as mounted in a 48-52 F-1? What I need is a reference point with respect to either the center of the fan pulley, crank pulley, or some other common point from either the frame or front crossmember. I think I mounted mine too low and that I may need to raise it about an inch or so. As pointed out in another thread, I'm having a problem getting a lower hose to the radiator without it being chopped off by the fan...
I could use a smaller diameter fan but I hesitate to do that and then set myself up for cooling problems!
Sounds like your 302 is in the right spot, I threw away the fan and installed a electric pusher fan in front of the radiator. I still had a problem with the lower hose being rubbed by the power steering belts, solved that with two hoses with a chrome kithen sink trap installed in the middle.( cut the trap to the length you need for the correct angle)
Bob
Bob
