1958 F600 Engine Swap Options
Engine Swap
I have a 57F600 with a 390FE and 5spd. You will need a bell housing from a later F series that had a FT so that the rear mounts will fit. Front mount from a 330MD will work with a little modification to the truck mount. I used a neutral balenced flywheel from a 330MD the HD style flywheels have a balence weight. You can use a flywheel from a pickup ,just be sure that you flywheel and starter are compatable , the old style starter uses a different tooth count than the later ones. Your radiator will work fine. Iused headers from a later 2WD pickup. The hydralic clutch slave bolts up OK. If you have any questions let me know.
Have A Good Day-----------Hotwrench
62surftruck
24
01-08-2011 08:10 AM
400 Ford
08-16-2003 07:12 PM
