97 F250 HD radio switch
Going from memory, the 97 f250 is the same body as the 92-5 f150. I would suspect those years of radios in any combo would slap right in and run. CD or cassette should make a difference on the plugs since you have a couple of power/grounds and then the speaker leads. That radio should have been a single din, of which there are alot of aftermarket options that should be comparable in price with better features than OE. Then pick up a $10 wiring harness and life is good.
jonmammenga
04-08-2017 05:25 PM
truszip
11-11-2004 04:59 AM
