Great and Cheap rust remover, not Syrup
Received 4,135 Likes
on
It depends on how tight the seam is - remember it's harder to get the acid out then in - this can lead to problems with paint bleed thru.
Now that I have answered your question I feel so much better
Anybody have an idea as to what could be added to the vinegar/water mix to make it into a gel and cling to vertical surfaces? I knew vinegar was a good rust cutter but I didn't know it would remove paint. Is it removing the paint or cutting the rust that the paint is attached to, just curious.
on
on
And that was the results after only two days, I'm going to be trying this on some small parts. I should of payed more attention in science class I guess, thanks for the pictures.
So the question that comes to my mind is: How come I haven't heard of this before?
So far as the gell question goes. Try mixing in some gelatin. You can buy it in the same isle they have the vinegar. Might work, might not, but don't know.
Another possible idea: soak down the area and lay a garbage bag over it. That will help hold on the vinegar, and prevent it from evaporating.
I'll test it to see if the addition of the gel agent doesn't counter its effectiveness. I guess I should have done a pH analysis prior to adding the agent.
#29
Originally Posted by 69supercj
Well that looks pretty good and from the pics it seems that it is taking the paint off of the non-rusted metal. I'll have to give this a try. Now back to my original question, does anyone have any ideas as to what could be added to this to make it into a gel?
#30
I was bored at work today so I thought I'd give this a try. I tried several gelling agents I have laying around and about when I was ready to give up I found some stuff that gelled.
